Originally Posted by
alexaescht
Oxygen and nitrogen? Water is made of two hydrogen atoms and one oxygen atom and heating water does not cause it to split up. Think about it, when you boil a kettle of water, the vapour that comes out as steam is water vapour, not hydrogen or oxygen as individual elements. Water will only split into hydrogen and oxygen through special processes. Heat will not do it.
Yes, the benefit of removing the water vapour is that the vapour pressure rises exponentially with temperature, rather than linearly from a base of ~ -273 deg C as ideal gasses behave (which nitrogen and most of the other gasses composing "air" approximate well at the temperatures that car tyres face). This is why the tyre pressures are so much more temperature stable with nitrogen fill.
Resident grumpy old fart
