If you guys haven't researched on the net, the next Polo GTI (updated for 2015) will have the 1.4ltr engine, 141kw and avail in Manual and DSG. It will only be single charged. The Polo GTI will continue to have the 1.4ltr engine, nothing bigger.
Here is the ballast. I'm not unsure it isn't sand-bagging, though I suppose they'd put it all the way across in that case, rather than in one corner.![]()
Now gone.... 2012 Skoda Fabia RS
[FONT=Franklin Gothic Medium]Matt
2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
Your point is?
From the above can we assume that the supercharger is being dropped in place of a larger turbo (the latter required to compensate for loss of supercharger)? i.e how do they propose to maintain/slightly increase power output. One would hope the revised engine has a fix for the oil consumption issues.
I'm thinking the lack of replies to the above means no one knows exactly what VW have planned for the revised/new GTI engineGuess we'll all find out in October!
Max kw figures only sell cars, they dont make them go fast. At the moment the supercharger would be having most impact at lower rpm and less of an impact at peak power which would be sourced mostly from the turbo. So you could take out the supercharger and it would have little if any effect on the peak kW. It will lose some bottom end so compensate the 0-100 time by adding a few kw peak. That can easily done with a tune along with all kinds of internal development work. Even if its faster on paper it might not be as nice to drive. Just supposing. Or maybe its an entirely different 1.4 litre.
