It's called axle tramp and is basically a resonance between the unsprung mass and the strut being driven by the grip and front end anti-dive/lift geometry.
Not a huge deal but will work your dampers a bit more than otherwise. To get rid of it, you need more compression damping (stock dampers usually have none), less grip (not the point of the exercise
), less anti-dive/lift (Whiteline WALK or SuperPro bushes with castor shift) or less unsprung mass (lighter wheels/tyres) - this will shift the resonance frequency up to a point where the tramp won't occur.
Resident grumpy old fart
