Im guessing you've checked for leaks etc. If there are no signs of damage, does it feel like youre riding on a very bumpy cloud? By bumpy I mean it bumps excessively.
You might just have worn out shocks.
This is more of a question than a problem, but instead of making an entirely new thread I thought this one would suit best.
People who have stock suspension on comfortline/trendline models, how far (roughly) does your suspension travel when going over normal speed bumps? Recently I've noticed that the suspension on my sister's Polo goes right down to the bottom, and actually hits the bump stops quite hard. This happens over basically every speed bump and it just doesn't feel right. Over the exact same bumps, at the exact same speed, our Megane doesn't go near hitting the stops at the bottom of the suspension travel.
Any thoughts, ideas, comments etc?
Thanks
Alex Aescht
MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
It seems a lot more 'crashy' than it used to when it comes to bumps. Small-ish bumps in the road become very pronounced when you're in this car.
I haven't checked anything because I honestly have no idea what to look for, however I wouldn't be at all surprised if something is leaking/the shocks are worn because we live on a bumpy, dusty dirt road so the suspension gets a good hammering every day.
Alex Aescht
I'd hazard a guess and say you've got worn shock(s).
Alex Aescht
Depends on if there's still warranty or not? How high are your km?
If there's still some warranty and the Km's aren't to high you could give it a good clean so it's not to obvious you live on a dirt track and try your luck with a warranty fix. You might find a one dumb stealer ship.
If not then hit the Melbourne boys up on the best suspension joint near you. Maybe try and find a more robust option to get more life on rough roads. Most anything aftermarket will last a bit longer then factory. Do a google search and see if there are heavy duty sets.
Alex Aescht
Whoa Nelly!,
My comment wasn't aimed at you. Unfortunately the quote system on here doesn't include all previous comments.
My frustration is when people tell me how to drive the car and cant see that electronics do fail occasionally.
Fair enough the clutch 'should' disengage in a perfect world when the brake is applied but it doesn't every time.
Use your left foot, right foot or elbow the car should stop.
My examples were to highlight that even a massive company like VW has electronics/quality control problems which luckily seems like no one on here has experienced.
Sorry if I've offended any VW fans.
Alex Aescht
