Page 150 of 181 FirstFirst ... 50100140148149150151152160 ... LastLast
Results 1,491 to 1,500 of 1805
Thread: New Polo problems - Register
  1. #1491
    Aug 2009
    Sydney,NSW
    Got my gti for 2weeks,checking engine oil and notice the coolant level is at just above min. Level. Is that normal when the car leave dealer?they only top it up to just above min. Level? Oil temp been fine at 95 degree highest since day1. Need to worry?
  2. #1492
    May 2013
    Qld
    Re: New Polo problems - Register
    Quote Originally Posted by POW View Post
    Does the coolant level rise to max when its warmed up with fans kicking in?
    Sent from my HTC_PN071 using Tapatalk 2
  3. #1493
    Aug 2009
    Sydney,NSW
    It raised up abit and will sat it is above the min line.i checked today when cold the coolant is just below the min. I read something about coolant burp,is that what happen?
  4. #1494
    Hey,
    Does anyone know what would make a squealing noise from the front suspension area when going over speed bumps? I think we may have suspension issues...
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  5. #1495
    AutoBahn
    Quote Originally Posted by alexaescht View Post
    Hey,
    With where you have described you live / drive...could be shock absorbers, get your local suspension store to check it out...sounds like general wear and tear rather than a "problem".
  6. #1496
    Quote Originally Posted by Hail22 View Post
    Yeah I wouldn't be surprised if it's the dirt roads that's caused it especially seeming there's a really bumpy (washboard) bit that goes uphill so there's a lot of axle tramp that goes on.
    Thanks.
    Alex Aescht
  7. #1497
    Sep 2012
    NSW
    For the first time (10,000km driven) I think I experienced a 'false neutral'.
    Pulling out of my street in 'manual mode' to get as much power down as possible to get a small gap in traffic. Revs did not go too high, but still in first, the engine lost power while I was on 80% throttle. The power died for around 1 second, then went on FULL 80% power again. It was extremely uncomfortable and very scary.
    Is this what is called a false neutral? or did I experience something different? Anyone else had this?
    Edit: adding that the engine/transmission was still cold at the time.
  8. #1498
    May 2012
    As long as it doesn't drop below min when cold its fine.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
  9. #1499
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by Zakarados View Post
    Kinda, but a full-on false neutral is when you go to take off at lights or pull into an intersection and all the car does is sit there shuddering like its running on 2 cylinders which can only be fixed by pulling the car into neutral and then putting back into a forward motion gear position.
  10. #1500
    Sep 2012
    NSW
    Quote Originally Posted by gavs View Post
    Thanks for the reply Gavs. Is this something I should contact my dealer about? I have a my 12 month service on Thursday.
