Page 135 of 181 FirstFirst ... 3585125133134135136137145 ... LastLast
Results 1,341 to 1,350 of 1805
Thread: New Polo problems - Register
  1. #1341
    Apr 2011
    Quote Originally Posted by gavs View Post
    2) pay for a dsg tune which alters the shift points in D and S and provides better clamp force through the early stages o the rev range to stop clutch slip, hence prolonging clutch life
    I like this option...I may as well chip the ECU too to get better fuel consumption too right?
  2. #1342
    Apr 2011
    Sunshine Coast, QLD
    Re: New Polo problems - Register
    They won't ever fix this problem mate. The problem they have is that TVS engineering who have written dsg tunes in the Netherlands (who also provide tech support to VW in the Netherlands) have solved this issue and for VW to have Borg Warner RE-write the code to the same specs as TVS then they won't achieve the same (bulltish) fuel consumption figures, they will be admitting they got it wrong and will also potentially be in breach of IP laws. Unfortunately, to get this solved you have 2 solutions. 1) drive in M all the time but this doesn't overcome clamp-force problems or 2) pay for a dsg tune which alters the shift points in D and S and provides better clamp force through the early stages o the rev range to stop clutch slip, hence prolonging clutch life
    Probably worth mentioning that if you fiddle with the DSG tune - even if WE know it will improve things - it will make it harder to make a claim for any DSG issues under warranty...
    It's a Catch-22!
    Sent from my mobile device using Tapatalk 2
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
  3. #1343
    Nov 2012
    Sutherland Shire, NSW
    Does anyone find their car has noisy door/window rubbers? Perhaps I'm being extremely pedantic (quite possible) but I find if I'm going over driveway enterances or very slow speed, bumpy corners I find the window or door seals are a little creaky. Mainly seems to happen with the fronts. You can replicate the noise if you push on the top part of your rubber window seal. Does anyone else have this issue?
    Current: 2018 Golf GTI Original | Manual | Tornado Red
    Previous: 2012 Polo TSI | Manual | Reflex Silver | Comfort and Sports Packs
  4. #1344
    Quote Originally Posted by TSI_Dan View Post
    Yeah I think lots of people have that problem.
    Both of my cars do it – I first tried greasing the seals but that didn't really work so I tried a wet, soapy sponge and scrubbed those felt seals at the top of the doors and where they touch under the roof.
    That has seemed to work, but it's starting to come back now.
    I've also heard of some people stopping this for good by buying some 6mm tubing and feeding it between the two felt seals at the top, but I've not tried it so who knows if it works.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  5. #1345
    Nov 2012
    Wetting the felt actually seemed to have work for now. Wonder how long it will last though, ahh well thanks for the tip Alex!
  6. #1346
    Jun 2008
    Ringwood, Victoria
    Gummi pfledge is your friend in this instance
  7. #1347
    May 2013
    Sunshine Coast, QLD.
    I've had this issue with our Polo GTi too (noisy door rubber seals). The dealer won't (can't) do anything about it. Their solution was the polish the door frame and use some VW lube stuff that's supposed to stop the noises (at $30 for 50ml bottle mind you), which it did for about 4 days. I've temporarily fixed it by just spraying some Silicon spray (pick it up at Repco or similar for about $5) on all the door rubbers and the felt at the top of the door.
    I'd be VERY interested in a more permanent solution to this issue though. Any more tips on what this, "Gummi pfledge" is? Or the process for inserting the tubing into the seals?
    Cheers,
    Brett.
  8. #1348
    Apr 2013
    Quote Originally Posted by Disciple View Post
    Cheers,
    Brett.
    Car Care Products / Einszett 1Z / Exterior / Exterior Trim & Plastic / Rubber Care Stick Gummi Pfledge
    no idea if it works though
    I'm still waiting for my Gti Polo to arrive but reading all the common problems and how to fix them in this excellent forum.
    Brian
  9. #1349
    The process for inserting the tubing into the seals?
    Writing up a guide now...
    Alex Aescht
  10. #1350
    May 2012
    I can't find it but I'm sure someone else has done it and posted a how to up.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
