for all you gti oil munchers due to the excessive oil usage and the replace pisston rings fix not working the new fix has now just been released as of yesterday the modified engine breather pipe 03c103474ad tpi 2025520/5 engine must be using over 500ml over 1000ks so you might still have to have oil consumpion tests also as part of the tpi is a software update for the engine ecu so all you boys that have chips might have to get reflashed by your tuners afterwards the pipe is an easy replacement and software update should only take no more than 2hours all up. parts may need to be ordered in so you could have a little wait.
- You may not post replies
- You may not edit your posts
Forum Rules
