Page 46 of 181 FirstFirst ... 3644454647485696146 ... LastLast
Results 451 to 460 of 1805
Thread: New Polo problems - Register
  1. #451
    Quote Originally Posted by gavs View Post
    Yes, mine has it though either I don't notice it anymore or it has died down a bit. I know exactly how to make it happen though and generally, I don't drive the car in a way to make it happen.
    To answer your second question, yes, they have. It's called the new 1.6 single turbo engine that is (in one form) going into the Polo WRC car. This has been such a major issue that VW will not admit to, they keep all dealings with this issue under the table and as one member on here found out on his golf, issued a gag order and threatened legal action.
    Gavs does this chirp affect only the 1.4 or the 1.2 as well?
    What's the cause?
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  2. #452
    AutoBahn
    Quote Originally Posted by 77kw polo TSi View Post
    What's the cause?
    The chirp is a GTI issue only, it has something to do with the twin charge, however i may be wrong.
  3. #453
    Sep 2011
    VIC
    Ok the chirp isn't that annoying at this stage it is not all the time so I will give it more time to see if it either resolves or gets worse.
  4. #454
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by Hail22 View Post
    Yep, the chirp only affects the GTI model. It happens when the friction material of the supercharger clutch slips. I have been able to make it chirp really short and sharp and also a bit more drawn out. By saying drawn out, I mean for around 0.6 secs. It generally only happens when the engine is turning over at low rpm in a specific gear and you put your foot down a bit, not enough to drop down a gear if you're in D, but enough to get the supercharger to engage.
  5. #455
    AutoBahn
    If only we could generate enough hot gas to attain this sound while down shifting love blown diffusers! instead of silly exhaust sounds pfft
    http://www.youtube.com/watch?v=BmGgv...eature=related
  6. #456
    Potts Point, New South Wales
    Have to say i was reading a bit further down in this thread and i noticed that people were pushing the engine really hard in its infancy to get it run in?
    I have to say being in the engineering world with my job etc i have NEVER heard of any engine getting run hard in its first few 1000km's. In my opinion the engine should have an easy time for the first few 1000km's. But to be fair i haven't had a Volkswagen before. interested in hearing why it is good to run the engines hard? At the moment im in the belief that you will be much closer to ruining valves and blowing a head gasket.
    Regards,
    Harry
  7. #457
    Aug 2011
  8. #458
    im skeptical.....you don't get anywhere near the rpm a bike gets....hmmm....will have to consult some fellow engineers!
  9. #459
    Jun 2008
    Ringwood, Victoria
    I've spoken with a few engineers in the office who either still work or have worked in different race categories around the world and they all say the same thing. To break in an engine softly goes hand in hand with the theory of running mineral oil for the first 2000 kms and then doing an oil change because of such poor manufacturing tolerances. The only reason to run in an engine softly is because of how poorly the engine was manufactured in the first place. With modern, higher compression and better manufactured engines, you are more likely to polish the bores by running in the engine softly. An old friend of mine specialises in building and ultimately tuning heavily moddified japanese motors, ie supra engines outputting in excess of 500-600kw of power and I've seen how they run these custom built, $20k+ engines (in parts alone sometimes) on a dyno and there is no easy running whatsoever.
    In my mind, there is no logical sense to run in an engine softly. I have used 250ml of oil in 10,000kms and I loaded up the engine so to me, it looks to have worked.
  10. #460
    I agree, I have followed the procedure in Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power for two cars (Astra 2.2 and Polo GTI 1, and two bikes (Zx6R and GSXR750) and all have run beautifully will very little oil usage between services. It's not really about revving the tits off them, rather loading the engine (both on throttle and more importantly off throttle).
