Page 45 of 181 FirstFirst ... 3543444546475595145 ... LastLast
Results 441 to 450 of 1805
Thread: New Polo problems - Register
  1. #441
    Jan 2011
    Perth
    Quote Originally Posted by 77kw polo TSi View Post
    I had this annoying rattle coming from somewhere in front of the dash, behind the steering wheel, and wasn't sure whether it was inside the cabin or inside the engine bay. Of course it only happened intermittently and only then with my foot on the brake and it in drive.
    That is until this week, when it kept making the noise whilst in park, jumping out the car at a carpark I traced the noise to inside the engine bay, and discovered these two pipes going down into a metal cavity, just behind the round radiator expansion tank (ball). I fund they were raised and didn't seem 'fixed' via any clips. Pushing them down into the cavity stopped the rattle. If it stays 'stopped' I'm going to push a piece of foam into the cavity to hold them tightly in place.
    Picture of cavity and pipes...
    I posted quite a while ago on doing this after a trip to the dealer who was unable to resolve the rattle.
    My fix was to use some rubber hose that plumbers use over copper pipes (about 300mm - 1200mm length can be purchased at Bunnings).
    Cut a 300 mm length and then cut a slit down the entire length.
    Unclip the fuel pipe (closest to the fender) and feed the rubber hose down over the top of the fuel line (whilst carefully wiggling) until it wont go any further.
    Trim of the excess and re-clip the fuel line.
    Worked like a charm - no more fuel line rattle.
  2. #442
    Quote Originally Posted by TCO View Post
    My fix was to use some rubber hose that plumbers use over copper pipes (about 300mm for each pipe - 1200mm length can be purchased at Bunnings).
    Cut two 300 mm lengths and then cut a slit down the entire length of each.
    Unclip the fuel pipes and feed the rubber hose down over the top of the fuel lines (whilst carefully wiggling) until it wont go any further.
    Trim of the excess and re-clip the fuel lines.
    TCO - wish I'd seen that one. But good to know it worked for you too. Today the rattle came back, so I used spare foam from my camera case and squeezed about 25cm of it down the left side of the pipes, up against the wheel well side. Rattle stopped and I think the foam will subdue the vibration that you can visibly see happening on the feeder pipe - the one in the picture with the big black clip. You can just make out that the vibration and rubbing has resulted in the black insulation around the nearby wiring harness rubbing off!!
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  3. #443
    Jan 2011
    Perth
    I went and had look at our POLO - it was only one pipe - I will edit my other post.
  4. #444
    AutoBahn
    Quote Originally Posted by dave_r View Post
    Though so, dealer tried to say it was probably cut in pre delivery.
    Another rattle? We did get a **** batch. The missus mentioned a rattling has started up again recently but its not exactly the same as the fuel line one.
    Will be the missus first and last VW I suspect, having to go back so many times is a dead set pain in the arse.
    If it happens again i will dump my car at the service centre....
  5. #445
    Jul 2011
    Hi all, just started happening the past few days. Everytime i sit it makes a creaking noise and also when taking corners at speed there's also creaking that comes from the the dash (this is not the rattle that others have experienced).
    I am booking it in for my dealer to have a look at, but just wondering if anyone has had a similiar issue and if they got a fix for this.
    Possible fix: I just adjusted the seat backwards and forwards a couple of times and then put it back to my preferred setting and the creaking was gone. Will have to check tomorrow to confirm but yeah very happy that it disappeared (hopefully for good).
    Last edited by babs; 24-11-2011 at 07:06 PM. Reason: got the fix for this...i think.
    2011 MY12 Polo 77TSI Manual Comfortline | Flash Red | Sportspack | Front Tints | Car Mats - Ownership taken 30th of September 2011
  6. #446
    Sep 2011
    VIC
    Has anyone had issues with their polo the same as the infamous golf TSI 'chirp'? I've just hit 8,500km and just noticed a faint cricket today!
    More importantly has VW come up with a fix for it yet?
  7. #447
    @#@^%$#%$&$ 12 DAYS . Got the car back today after waiting for parts. drove 50km + THE CLUNK IS BACK!!!! What the hell....i give up
  8. #448
    Quote Originally Posted by Volksie View Post
    Onya VW. Another clueless dealership swapping anything out under warranty. Another unhappy customer. why don't VW just knock a couple of grand off each car and let customers fend for themselves for an independent mechanic...
  9. #449
    Yeah it will work way better. think some pvt mechanics could have solve this days ago.................
  10. #450
    Jun 2008
    Ringwood, Victoria
    Yes, mine has it though either I don't notice it anymore or it has died down a bit. I know exactly how to make it happen though and generally, I don't drive the car in a way to make it happen.
    To answer your second question, yes, they have. It's called the new 1.6 single turbo engine that is (in one form) going into the Polo WRC car. This has been such a major issue that VW will not admit to, they keep all dealings with this issue under the table and as one member on here found out on his golf, issued a gag order and threatened legal action.
