Originally Posted by
TCO
I posted quite a while ago on doing this after a trip to the dealer who was unable to resolve the rattle.
My fix was to use some rubber hose that plumbers use over copper pipes (about 300mm for each pipe - 1200mm length can be purchased at Bunnings).
Cut two 300 mm lengths and then cut a slit down the entire length of each.
Unclip the fuel pipes and feed the rubber hose down over the top of the fuel lines (whilst carefully wiggling) until it wont go any further.
Trim of the excess and re-clip the fuel lines.
Worked like a charm - no more fuel line rattle.
TCO - wish I'd seen that one. But good to know it worked for you too. Today the rattle came back, so I used spare foam from my camera case and squeezed about 25cm of it down the left side of the pipes, up against the wheel well side. Rattle stopped and I think the foam will subdue the vibration that you can visibly see happening on the feeder pipe - the one in the picture with the big black clip. You can just make out that the vibration and rubbing has resulted in the black insulation around the nearby wiring harness rubbing off!!
MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
