Page 176 of 181 FirstFirst ... 76126166174175176177178 ... LastLast
Results 1,751 to 1,760 of 1805
Thread: New Polo problems - Register
  1. #1751
    Sep 2012
    Perth
    Quote Originally Posted by gavs View Post
    A honda dealer won't be able to diagnose squat about a dsg. If it's the clutch packs (which will be under statutory warranty, if they say it's not, say that you will see them in court) you can quite easily demonstrate it.
    Slowly approach a corner in D, making sure the car is in D2, it will be until you stop due to the VW idiot software programmers. Go as slowly as you can as you start rolling through the corner, then feed in about 30-50% throttle. If you get any shudder, your clutches need replacing.
    Once you make the technique work, it's easy to replicate for a dealership.
    Well, I had to try this for myself, exactly as you described. I didn't get any noticeable shuddering, but I had the window down as I often do, and instead of the usual clicking sound, I heard what sounded like marbles rattling in a tin. Happened three times in a row. No noticeable issue with acceleration or shaking, but the rattling sound. The obvious question: is this normal?
    Now gone.... 2012 Skoda Fabia RS
  2. #1752
    Jul 2011
    Quote Originally Posted by Rubbadub View Post
    Shuddering or constant slipping (random rpm spikes) are the only real signs of a bad clutch. Any other noises are considered annoyingly "normal". They can come from anywhere from the dual mass flywheel to the turbo wastegate (77tsi models only). Apparently the supercharger clutch on the 1.4twin charge can also rattle / make a chirping sound...
    Or the fuel lines...
    ...or the A/C lines...
  3. #1753
    It's the clutch. Getting my one replaced. It'll be the second clutch in my GTI.
    [FONT=Franklin Gothic Medium]Matt
    2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
    Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
  4. #1754
    Jun 2008
    Ringwood, Victoria
    This sounds more like the 3rd gear selector fork rattle. Due to its position in the gearbox, when 3rd gear is pre-selected the fork can rattle around seemingly with no adverse effects.
  5. #1755
    Mar 2014
    Mernda, Victoria
    I tried this technique yesterday and haven't experienced any shuddering. It actually hasn't shuddered at all after I reset the throttle body position, well I think I did anyway.
    Sent from my Nexus 5 using Tapatalk
  6. #1756
    Sep 2012
    Perth
    Thanks for your responses. Good to know there's one less thing to worry about.
  7. #1757
    Quote Originally Posted by alexaescht View Post
    Tonight's episode of Polo problems, brought to you by my sister's 66TDI Comfortine:
    http://youtu.be/4IceqGrNNG0
    Engine light, ECU light, and limp mode. Gotta love VW motoring.
    Should have bought a Corolla at this rate of failures...
    Booked in for Monday. Let's see what's wrong this time...
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  8. #1758
    Jan 2014
    First issue occurred over the weekend for me. Check engine light came on. Took car to VW and was asked to bring it back Monday. Start the car today and what do you know no light to be found. Hopefully this isn't a sign of things to come. Also seem to have an intermittent issue with the usb input dropping out.
    Sent from my HTC One using Tapatalk
  9. #1759
    The little Polo was looked at today, and the DPF (diesel particulate filter) is full of ash, which, unlike soot, cannot be burned off through regeneration. They tried a forced regen, then an emergency regen but with no luck. A replacement DPF is circa $3500 and that is without labour.
    Considering VW say the DPF should be maintenance free for about 300,000 kms, or roughly eight years, we will push as hard as possible for this to be replaced under Australian Consumer Law or VW goodwill.
    I'll also bring up the fact that we told them, on multiple occasions, that the car was not running properly/stalled while driving etc. and that they failed to replace any defective part until several months later, denied the car was at fault, and blamed it on "your driving style".
    The parts at fault back then were the injectors, which were causing the DPF to regenerate every two days which I think would significantly reduce the working lifespan of the unit.
    Hopefully we can come up with a solution for this...
    Alex Aescht
  10. #1760
    Oct 2010
    Melbourne, VIC
    That is a shocking run your family has had with this car, Alex (mice eating wiring, damper failure, brakes...) but this takes the cake.
    Would you mind reposting this in the Diesel subforum, plus the followup? One of the experts there might even be able to help.
    Resident grumpy old fart
