Page 171 of 181 FirstFirst ... 71121161169170171172173 ... LastLast
Results 1,701 to 1,710 of 1805
Thread: New Polo problems - Register
  1. #1701
    Mar 2014
    Byron Bay, NSW
    Hi guys,
    got our Polo Trendline about a month ago. Stoked with the car apart from one flaw.
    Every morning since we picked it up, it never starts first go. Usually takes 2-3 goes to get it to start. It turns over but doesn't seem to want to start up. Once started it's fine all day, never another problem.
    Doesn't seem to matter whether it's a cold morning or not, although does take maybe 5 goes on a super cold morning. And does't matter whether it's on an incline or decline. Tried a few other things and can't seem to remedy it.
    Took it back to the dealer after 2 weeks of putting up with it to be told it is a "software issue" that VW Oz is aware of and are working on a fix. Sounds a little fishy to me? Obviously my next step is to take it to a different dealer, but getting the feeling I may be told the same thing, can't hurt to try though.
    Anyone else had a similar issue with theirs? Been trawling around and thinking maybe asking them to check the temperature sensor? Mightn't be working and hence not supplying the engine with enough fuel on startup?
    Forgive me if I sound like an absolute rookie, as that's pretty much what I am!
    cheers
  2. #1702
    Aug 2013
    Newcastle, NSW
    We don't have that problem on our MY13.5 Trendline. You may want to try a different brand of fuel and make sure it's 95RON or even try some 98RON. Had a bad batch of fuel once and caused mayhem with loss of power and the fuel economy.... doubled.
    I think the software is dim witted as there is a slight lag when taking off (manual transmission) and revs fail to build up on steep hill starts at times. No errors were logged at the last VW check.
  3. #1703
    brisbane
    The 1.4 cgg engine is bad for this they have been working on a software update for over 4 months now and should be available next week
  4. #1704
    Jul 2012
    So I've discovered another problem with my Polo (surprise...?) When accelerating and changing from 5th to 6th the car seems to "jump" revs as if its slipping the clutch. This is just my assumption that its slipping clutch. Also when under hard acceleration, the brain(mech) seems to take a second or 2 to change from 5th to 6th.
    Does anyone know if this is clutch or mechatronics problems?
  5. #1705
    Mar 2014
    Byron Bay, NSW
    Quote Originally Posted by rabbitz View Post
    Definitely not the fuel as we've only ever put 98 in it, from either BP or Caltex. Never the budget places.
    I can't see how it can be software if it just does it on cold starts then is fine for the rest of the day? They say there were no faults showing up but I'm skeptical.....
  6. #1706
    Aug 2012
    Lately, I've noticed that my steering has developed a knocking sound when I quickly turn the wheel from one direction to another (i.e. when performing a parking maneuver). It also feels much lighter than it used to be (I'm not a fan of lightweight steering).
    Any ideas what could be the issue?
    Thanks in advance.
    MY16 Golf GTI Performance Pack
    Previously: MY12 Polo 77TSI
    In The Family: MY15 Golf 103TSI Highline & MY15 Audi RS3
  7. #1707
    Pacific Paradise QLD
    Quote Originally Posted by Barracuda View Post
    Thanks in advance.
    Has someone pumped the tyres up recently
  8. #1708
    Aug 2012
    Thanks for the quick reply, Hillbilly!
    I had them filled with Nitrogen a few months ago. Steering still felt normal after it was done.
    The dealership also replaced the steering rods under warranty during the 1Y service. I didn't even mention them, they just said that they were 'worn'.
  9. #1709
    My Intake Manifold is broken... Engine continues to go into safe mode and struggles in power to drive.. Have to wait 3 weeks to get it looks at! Unacceptable by me to wait weeks to get it properly looked at and fixed as all they've done is reset the computer for it to be normal until then and my engine light keeps going on.
    [FONT=Franklin Gothic Medium]Matt
    2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
    Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
  10. #1710
    Jul 2011
    Quote Originally Posted by MJKooLio View Post
    How is it broken exactly? Is it a crack or you just think it's broken?
    The only good thing about these engines are they are turbo and direct injection. You can have leaks all though the intake tract and it still runs - normal I may add. I broke one of the seals on the intake from the turbo when I was putting it back on. I only noticed somthing was wrong becuase I could hear it loudly hissing as the charge air passed the seal. The engine ran just as normal and just compensated the wastegate actuator for more boost.
    So maybe it's somthing else...
    Also 3 weeks is bull. When one of my HT leads went I called them up on the Sat and they put a emergency booking in for the Monday car was fixed by Tuesday arvo. Just complain or ask another dealer. Anything that causes a fault big enough to stop normal operation of vital components like steering, brakes, engine, gearbox or electronic assists should have top priority above all else.
