Page 40 of 181 FirstFirst ... 3038394041425090140 ... LastLast
Results 391 to 400 of 1805
Thread: New Polo problems - Register
  1. #391
    Jan 2011
    My back right seat is making some rattling noise. It does not make the noise if someone is sitting on the seat or if the seat is folded down. only when its in the normal position. need to get it checked out
  2. #392
    AutoBahn
    Quote Originally Posted by JexL View Post
    Yeah who did you buy your car from?
    if its CCC they're really good early in the morning with the availability of technicians
  3. #393
    Jan 2011
    got from mccarrols waitara. probs take it back to them but i guess i could give CCC a try since im always in the area
  4. #394
    AutoBahn
    Call them first mate, idk whether they cover cars not bought from Inchape group (Denlo, CCC)
  5. #395
    Mar 2011
    Brisbane, Queensland
    Had another rough idle at startup a couple of days ago and a random drop in revs just sitting at the lights. That and ive had the "rattling noise from behind the dash" which will happen at start up and then disappear as soon as i start driving and wont return for a couple of days.
    Think i might take it in for a look see with the rough idle again.
    2011 VW Polo 77TSI | Manual | Savannah Yellow | Comfort Pack | Sports Pack |
    Installed: Whiteline Rear Sway Bar, H&R Springs, Resonator Delete
  6. #396
    Aug 2011
    Hey Guys. I have a TSI manual and also have had the same problems, the rattle was fixed with a fuel line replacement and the first time the car was idling rough was fixed with an ECU update. The rough idling has started again though and as of yet they can't find what the problem is. Im going to try switching from BP ultimate to Caltex vortex and see if it makes a difference. I understand they are both 98 but its worth a shot I guess.
  7. #397
    Jan 2011
    Found a boost leak from the supercharger outlet, which needed to be replaced... this is after replacing all the piston rings :/
    Bloody thing just keeps getting worse and worse being in the shops for a month.
    Anyone in the eastern suburbs of Melbourne with a GTI? I'm still getting a air vacuum squeal sound after the repair and need to compare it with another GTI.
  8. #398
    Jun 2008
    Ringwood, Victoria
    Yeah mate, send me a PM, more than happy to help you out. Am in Ringwood, just let me know
  9. #399
    Mar 2011
    So its just under 2 months now since I handed my car over to VW.
    The new...new engine arrived in the country and has been fitted into the car, apparently it has no odd sounds or anything so far and the guys are going over everything to make sure its ok, so i'm crossing everything that I get it back on Monday.
    The 1st new engine they gave me when they turned it on struggled to start and had piston slapping and valve timing issues. fun times.
    2010 Polo GTI 5dr, reflex metallic silver, MDI.
    Now Replaced With
    2012 Polo GTI 5dr, Candy White, Sunroof, Detroits
  10. #400
    AutoBahn
    Quote Originally Posted by Miles Away View Post
    How long have you owned the car for?
    This is a disgrace how a new car is going in for a new engine you would think this sort of issue would pop up during the engine run in stage at the factory/plant.
