Page 169 of 181 FirstFirst ... 69119159167168169170171179 ... LastLast
Results 1,681 to 1,690 of 1805
Thread: New Polo problems - Register
  1. #1681
    Jun 2008
    Ringwood, Victoria
    I just the squeaking passenger chair sorted in mine as well as the collapsed drivers side outer bolster. No more squeaks! They replaced the whole seat base foam and put felt on the metallic parts in contact with the foam that caused the squeaking.
  2. #1682
    Mum got into the Polo this morning to head off to work, and the battery was flat. Nothing was left on – no lights, radio etc. Jump-started it with the Megane and hoped it would start for her after work, but it didn't. We drove down and jump started it again, now it's at home and I've connected the battery charger. I'm sure it'll start tomorrow morning, as it's been on the charger, but I'm feeling like it won't want to start in the afternoon again.
    Does anyone know what could be draining the battery when the ignition is off, or do you think the battery itself could be at fault?
    Cheers,
    Alex.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  3. #1683
    Mar 2011
    Wollongong
    3 years would be the minimum life you would expect from a battery under regular normal use and temperatures. You may have just been unlucky to get a battery that is at the low end of the average.
  4. #1684
    Quote Originally Posted by alexaescht View Post
    Cheers,
    Alex.
    Quote Originally Posted by amazeer View Post
    The RACV should be here near midnight to install a new battery. The car needs to be used tomorrow so it had to happen tonight.
    Alex Aescht
  5. #1685
    VW Osborne Park fixed my squeaky passenger seat!
    [FONT=Franklin Gothic Medium]Matt
    2015 Skoda Octavia RS | Combi | DSG | Metallic Grey | Tech Pack, Every Option Except Leather |
    Prev: 2012 VW Polo GTI | 5dr | DSG | Reflex Silver | RCD510 |
  6. #1686
    Feb 2014
    canberra
    Just bought mine, having a few small issues, might need to read the manual, but has anyone had the following issues?
    Turn on the front fog lights, turn them off, and then one of the fog lights stays on
    2nd, the bluetooth touch screen sometimes doesn't turn on when I start the car, which is annoying.
    Thanks
  7. #1687
    Aug 2009
    Sydney,NSW
    The bluetooth screen,if u sit in the car n wait for 30sec before you turn on the car.it will turn on,its annoying so i just use the rcd510 directly.
    Sent from my GT-I9505 using Tapatalk
    2013 POLO GTI Black
    2005 MKV 2.0 FSI Black
  8. #1688
    Quote Originally Posted by Cejay View Post
    Thanks
    Fog lights: are you sure you haven't left an indicator on or have the steering wheel turning to one side? It's likely to be the cornering light staying on.
    Alex Aescht
  9. #1689
    Feb 2014
    canberra
    Fog lights: are you sure you haven't leNew Polo problems - Register-uploadfromtaptalk1395645836170-jpgft an indicator on or have the steering wheel turning to one side? It's likely to be the cornering light staying on.
    No I havent, see attachment , I discovered today that one foglight is also on when I turn the headlights on, this is with the front Fog lights in the off position
    Thanks
  10. #1690
    Feb 2014
    canberra
    No I havent, see attachment , I discovered today that one foglight is also on when I turn the headlights on, this is with the front Fog lights in the off position. Both go on when you turn the front fogs on
    Thanks
