Page 138 of 181 FirstFirst ... 3888128136137138139140148 ... LastLast
Results 1,371 to 1,380 of 1805
Thread: New Polo problems - Register
  1. #1371
    AutoBahn
    Quote Originally Posted by nomadx38 View Post
    Na leads are fine physically on the outside - just not getting a spark through by the looks of it. No burning or smell and I would know I'm always looking under the bonnet and checking things so its not neglect.
    I want to blame the service department but if no fault was stored (which I know it wasn't because I check with VCDS whenever I do changes) then I guess it's not there fault, they didn't know.
    And what do you mean check the seals on the cylinders? The engine is fine (to the best of my knowledge) the cylinder was deactivated after it noticed it knocking so no fuel was been pumped into it.
    Was interesting though was just driving normal, started going up a hill and heard a bang (could have been the engine or just a pot hole) and then all the engine lights came on and it limped up the hill like a dog
    As the Irish say: To be sure to be sure (not joking).
    What I meant to say is have the block inspected (long day in the sun and on the water so bare with my bad reply!)...sometimes things are not picked up by sensors or VCDS. For all you know there may be other problems, are the spark plugs in good condition / new?, you could of possibly bought tainted fuel from your local servo? (some stations have a tiny amount of water however the lazy ones that don't check and maintain their tanks have a lot of moisture). I would assume its a fuel / Spark plug issue.
  2. #1372
    Jul 2011
    I filled my tank up at the start of the week as it was running fine until just now so its not fuel. Spark plugs are original and I pulled the number 1 cylinder out and it was fine (a tad of carbon) but nothing out of whack, and as i said I changed the leads over from first to third and first ran fine and third was faulty so I think it's just the cable...
  3. #1373
    Jun 2008
    Ringwood, Victoria
    Not uncommon for a plug lead to fail, but they generally take a lot longer then 45,000! Still, if its jus a lead then that won't cause any other issues I can think of.
  4. #1374
    Jul 2011
    Got the car back today, its running - that's the only positive.
    The negative - they have cut the new wire and tried to cover it up with plastic tubing (though they say that's part of the new "design" which doesn't fit in the holders and hangs over the exhaust!!!).
    Now I have to go back again before moisture goes in the wire and shorts out internally or it arcs back to the body 😡
    I think it's safe to say there isn't a single dealer in Victoria who is competent...
  5. #1375
    May 2012
    Dealer had my car for three weeks because the FPR fuse fell out of the holder.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
  6. #1376
    Jun 2008
    Ringwood, Victoria
    Now I have to go back again before moisture goes in the wire and shorts out internally or it arcs back to the body ��
    And which dealer is that.....? Though unfortunately I think I know
  7. #1377
    Jul 2011
    Yes Gavs you know who! I should just do everything myself i think...
  8. #1378
    May 2011
    Without going back over the 138 pages - is there a solution for a squeaky drivers seat. It's driving me completely mental. Hit a bump and it squeaks, turn a corner and it squeaks, accelerate and it squeaks, drive it cold and it squeaks.
    Arrrgggghhhhh! I've got the normal tartan GTI seats - not faux leather.
    Polo GTI - 5 door - Candy White, Xenons, Comfort Package, Audio Upgrade, Bluetooth, Parking Sensors and Tint
  9. #1379
    Mar 2011
    Quote Originally Posted by prcurrie View Post
    I've had my seat fixed for this same problem. Took VW 2 cracks to get it fixed and it's not uncommon either.
  10. #1380
    May 2012
    Melbourne, VIC
    Hi guys
    Haven't read through every single post in this thread - just a general scan.
    Had my Polo GTI MY 12.5 for exactly a year now, and just starting having some problems with rough idling. Some days it is fine, others the whole car trembles.
    Taken it to VW service twice - the first time was a general check over where no fault was found. The second was for software updates.
    I'd like to have full faith in the service team, but can't help feel a little anxious/annoyed over the issue.
    Anyone had a similar issue or know what it may be?
    Thanks
    Jess
    POLO⎜GTI⎜MY12.5⎜BLACK⎜5 DOOR⎜Comfort Pack⎜Protection Pack
