Page 113 of 181 FirstFirst ... 1363103111112113114115123163 ... LastLast
Results 1,121 to 1,130 of 1805
Thread: New Polo problems - Register
  1. #1121
    May 2011
    Anyone know what the costs are to replace:
    - Clutch Packs
    - Mechatronics Unit
    - Whole DSG Transmission
    on a 7spd (DQ200) box????
    Trying to tally what 3 clutch packs and a new transmission will have cost VW
    Polo GTI - 5 door - Candy White, Xenons, Comfort Package, Audio Upgrade, Bluetooth, Parking Sensors and Tint
  2. #1122
    Mar 2012
    Cronulla, NSW
    Wow, big job, and very expensive. The mechatronics unit alone will cost anywhere between $4000 - $7000 from what I've heard on these forums. Hopefully VW took the hit and not you.
    Current Ride: Golf GTI Mk7 MY2014|DSG|Carbon Steel
    Previous Ride: Polo GTI MY2012|DSG|RNS510|Shadow Blue|Lenso GF7 18” rims
    Instagram: @lemonskin
  3. #1123
    Sep 2012
    NSW
    Quote Originally Posted by Zakarados View Post
    2nd Jan 2013: Cylinder 4 misfiring. Cause was oil dirtying the spark plugs. Fix was a software upgrade and cleaning spark plugs (how would this fix the issue?!?!?!?!?!?).
    25 Jan 2013: Came back from holidays and put 100km on the car. Cylinder 4 is misfiring again, GTi got towed to storage and wont get to VW until Tuesday.....
    Getting very annoying... Has anyone else had this issue?
    So I got the car back on Friday. It seems the Coil Pack(ignition coils) had failed on cylinder 4 again. Coil pack and Spark Plug was replaced. It seems to be running normal again for now. I also noticed the dash rattle is back after this repair!!! so annoying! I will wait a few weeks to see if the problem comes back before I send it back in for the rattle fix.
  4. #1124
    May 2011
  5. #1125
    Sep 2012
    NSW
    FK ME! engine light and EPC light on again, same issue I had on 2nd and 25th of January 2013..... Also still getting high oil consumption and exhaust splatter on the hatch.... I have had enough, I will be asking for a new car or REFUND... Five times to the service center, three of which have been towed, in four months. WHAT A FKN JOKE.
  6. #1126
    Jul 2012
    Not so much a problem but my tyre pressure light keeps coming on! So annoying haha.
  7. #1127
    Jul 2011
    Have you tried resetting the sensor using the button in the glove box once you have pumped up the tyres?
    Polo 6R GTI - Candy White | MY12.5 | 5 dr | Weitec Hicon GT | OZ Ultraleggera | SPOC - 1st Four
  8. #1128
    Jul 2012
    Yea do it every time.
    Also just an observation but my oil level hasn't dropped much/at all and I'm at 7700km. I remember being told and also reading after a certain number of k's (5000 I think) oil consumption should go down.
    Only problem now is the squeaking seats...and yes I have the alacantara seats.
  9. #1129
    Sep 2011
    Quote Originally Posted by jayc29u View Post
    I found if there's a significant difference between tyre pressures (not just low pressure) the light comes up.
    MY11.5 6R GTI 3 DOOR
  10. #1130
    Jul 2012
    Melbourne, VIC Northern Suburbs
    Question Windscreen/Rear Window Washer Jets
    Is anyone else underwhelmed by the windscreen washer jets? Anyone had an intermittently leaky rear window washer jet?
    My windscreen jets spray a fine but non-uniform mist onto the screen and there seems to be a significant amount of overspray that shoots off to either side without hitting anything on the car at all. Basically there is a lot less water hitting the screen than in any other car I've driven and it takes a fait bit of work to achieve any sort of cleaning action.
    The rear window jet is the opposite - one very strong stream onto a spot the size of a 50 cent piece but at least the volume allows the wiper to do a decent job with just a couple of passes.
    The most annoying thing is that the rear jet seems to leak. Not constantly, but bumpy roads and use of the front wash/wipe results in a trickle of water down the rear window, tailgate and bumper which then collects dust and looks pretty bloody awful.
    I'll mention the leaky rear jet when I take it in for it's initial check-up this week but just wondering if the windscreen washer jets are supposed to be as I've described them?
    Polo GTI MY13 (CTHE) | 5D | CW | Sunroof | DL Tint | VW Handy Adapter for iPhone 4/4S | DHL disabled
    VCDS tweaks: XDL - Strong | Brake Assist - Hard | Auto Lock Doors/Hatch - On | Two Stage Unlock - On | Audible Locking - On | Lane Change Function - 4 flashes
