Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: New Headunit
  1. #41
    Feb 2010
    When the head unit turns on, it sends out the remote turn on wire signal, which turns on the relay, grounding the parking brake The 86,87,85 & 30 are terminals marked on the relay.
    The specific relay you are after is a 12V single pole, double throw relay.
    2020 VW Golf R
  2. #42
    Oct 2010
    Quote Originally Posted by Allegiance View Post
    Got it, I picked one up this morning. Will install next weekend when I'm putting in the rest of my gear (speakers, amp and sub).
    Golf GT Sport TDI
  3. #43
    Feb 2010
    Quote Originally Posted by jazd View Post
    Have you got a Polo or the MK5 Golf GT in your sig?
    2020 VW Golf R
  4. #44
    Oct 2010
    I've got a Golf as per sig, just posted in here because you had the same headunit.
    Golf GT Sport TDI
  5. #45
    Feb 2010
    Ok that makes sense. I was going to give you advice on running the amp wires in but it will be redundant.
    2020 VW Golf R
  6. #46
    May 2010
    Quote Originally Posted by Jasonpb View Post
    Took me five minutes to install the mic in the stock location (interior lights) then again I installed the RNS-510 and 730c bluetooth kit into the polo and it only took me probably 30-40 minutes all up. Why would you install the mic anywhere but the stock location? cable not long enough?
    Hey Jasonpb did you replace the RCD-310 or 510 with the RNS-510? I need to find out if changing the RCD-310 to a RNS-510 will be straight forward. Chances of you flying to Sydney to do an install?
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  7. #47
    Jul 2010
    Perth
    Quote Originally Posted by REXman View Post
    I replaced a RCD-310 with an RNS-510, as long as you have a VCDS cable it's pretty straight forward. I had to change it over when nothing had been labelled in the ross-tech software but that's all there now.
    It's easy to do, real easy.
  8. #48
    Jan 2011
    Perth, WA, Australia
    Can anyone tell me where to buy the Fascia kit for a 2011 Polo in Perth? Or even online?
    Is it the same mounting kit as the Golf?
    Sep 2010
    Has anyone tried installing an Alpine unit in their Polo? I understand they make a kit now that allows for any of the units to be fitted in like a factory fit (Apparently it works with the steering wheel controls as well).
  10. #50
    Dec 2007
    I'm wondering why you wouldn't choose a navigation unit as well as the A/V and BT functions.
    The AVIC-F320BT is the same price but has the Navigation.
    (I haven't done an audio spec comparison, so maybe the A/V unit is much better at the audio function).
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
