I'm no expert (like most forum users out in the world!) but in regards to DPF, if you aren't going to be getting it up to temp (I'm using a Suzuki Grand Vitara as a benchmark here) then you will be up for a hefty price tag come replacement time because if you don't regularly run it up to temp to burn off all that soot that gets built up, night night DPF to the tune of $5k, knowing VW, add another 50% on top of that price locally!
This is why "Ad Blue" is being used now, to eliminate the need for a DPF. I don't think the 66TDi is an Ad Blue car, so this is redundant in this situation but it is the alternative.
I thought that Savannah Yellow was being discontinued.... Either way, you're going to get a miserly engine with plenty of poke for the daily commute and when benchmarked against the competition in the same price bracket, a pretty good little car. My choice? 77TSI because of the power as well as the torque![]()
