Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: New Climatronic group order
  1. #21
    Does anyone know if you can install one of these modules in a MY11 GTI that does not this style of module already (has the dials)?
  2. #22
    Feb 2008
    New Zealand
    hey why dont you guys get some polarizer film
    peel it off the standard Blue with Black Cyphers Display
    and then apply the new Polarizer film rotated 90Degrees
    that will give you a screen with Black Background and Blue Cyphers!!!
    and if you want to go further you can do a LED swap Blue in exchange for White..
    This is what it kinda looked like originally
    then after i did the Polarizer replacement (rotation replacement)
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
  3. #23
    Apr 2012
    Ok reviving a really old thread but after some googling and some inspiration from gavs I managed to find this which funny enough reverted back to gavs and my inquiring regarding getting a swap done over for the new white on black climatronic unit.
    I was thinking of doing the LCD (Polarizer replacement) swap myself just wondering can it easily be done?
    Otherwise anyone got some more info, as most of the links here are broken or outdated?
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  4. #24
    Jul 2011
    Yep bassik quite easy to do. Just involves taking off the radio trim and taking out a few screws. I'll get you a copy of the official removal manual which should assist you step by step
  5. #25
    Apr 2012
    Quote Originally Posted by nomadx38 View Post
    Thanks nomadx38 don't quote me but maybe I came off a little dumper then usual. I was referring to the actual LED backlight inside the Climatronic display LCD. I've taken the Climatronic control unit off before when I installed the Bluebooth behind the RCD.
    Although I could be silly and you actually do have official removal manual to do the LED black/white/blue conversion?
  6. #26
    Jul 2011
    Haha all good mate, I only have the manual to remove the whole climatic display. The whole unit is one part and must be discarded / replaced as one when faulty (in other words VW does not do any repairs on the unit as it is not user serviceable)
    This doesn't mean that you cannot do it though, it's just that there won't be any official documentation out there for you. As I have a crappy manual one I can't even look at mine to make a guide.
    If you can convince Gavs to give up his old blue one for me to have a look at, I could probably write a step by step walk through (if its possible)
    As it stands though you will have to have good electrical skills to unsolder the old LEDs (if they can be) and would have to expect that it will be a white background with black writing (unless you get that polarising film to up over the top as well before you close up the unit.
    Sounds like a fun job to do but as I said I got manual cheapness!
  7. #27
    Apr 2012
    Yeah your right if I had a spare to work on it would be fun and I'd have a crack but I don't want to end up breaking mine and then having to spend that $700 to get a new one.
