seeing as you're going down this path, i'd also recommend that you get some decent fluid and have the old VW crap bled out....
during intense mountain pass runs, the first thing to go [for me] was the fluid- it started boiling REAL quick.
It takes shorter time to bed in slotted discs. I would say that if you did 50km they should be already bedded in.
Don't try to bleed the brakes yourself, they should be pressure bled. I would go to VW dealer and explain the situation and even if you pay for bleeding the brakes and they work properly after, it's worth it.
Allegiance..... how did the brake upgrade work out?
Was it work the changes or is it better to upgrade calipers and disks etc....
[/COLOR] 2016 VW Golf GTI MK7 40 Years, DSG, Tornado Red, Tinted Windows,
2016 VW T6 Multivan Generation Six, Cherry Red with Candy White, VanEssa System with Kitchen, Mattress, Storage Bags, Swivel Seat, Roof Racks with Thule Pod, Dometic Anthracite Awning, Blackout Curtains, Bonnet Bra plus more ..
I can't say I found the stock brakes to be a problem and I've given the car a good workout around the twistys and some higher speed stuff. I think you just needed to get used to them from which ever car you came from? They did feel a bit soft initially to me but just took some adjusting to.
I have found the new pads and discs to be quite good. I do notice they are better in the wet. I only did discs and pads. If I was to buy again though I would probably go something of higher performance.
2020 VW Golf R
I have and as a light was turning Green to Orange (Near a safety camera) no shuddering or ABS used, very good![]()
Maybe there was a change to the MY11? My last car was a non-turbo impreza so I dont think the brakes on that should be that much better.
2020 VW Golf R
There has been changes including software campaigns which recitfied a few issues, that and the gear knob is much better then before.
