Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
Thread: My new wheels for my polo :)
  1. #21
    Jan 2009
    Quote Originally Posted by llai8501 View Post
    So 215/35 will fit but not be road worthy?
    Something like that, yeah.
  2. #22
    Jun 2013
    Wagga Wagga
    Nice rims by the way! I am thinking the something similar for my Fabia.
    The 215/35 R18's will be fine, but yeah as the others said just make sure they're 87 load rated.
    Diesel_vert is getting down to the nitty gritty of the tyres, when they're talking about the 87V XL & 84V XL, which is what your tyre supplier should have done for you!
    If you want to read about it it can be found here:
    Tire code - Wikipedia, the free encyclopedia
    The 87 and 84 is the loading index for each tyre. The V is the speed rating. The XL would just mean extra loading ie if the tyre had this marking on it, it essentially means it can handle extra loading.
    So, the:
    87V XL translates to 87=545kg V=240kmh XL=extra load
    84V XL translates to 84=500kg V=240kmh XL=Extra Load
    Also here are some good rim and tyre calculators:
    tyre calc: Tire size calculator
    rim and tyre: Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    Tire Size Calculator - Tire & Wheel Plus Sizing
    Skoda Fabia vRS
  3. #23
    Jan 2009
    Broadly, there are two types of passenger tyres:
    - Standard Load
    - Extra Load or Reinforced (same thing)
    So for instance:
    A standard load 215/35 R18 tyre will have a load index of 80.
    An extra load 215/35 R18 tyre will have a load index of 84.
    A standard load 225/35 R18 tyre will have a load index of 83.
    An extra load 225/35 R18 tyre will have a load index of 87.
  4. #24
    Jan 2009
    blankedy
    What offset are the wheels? depending on where they sit, you may struggle with wider tyres rubbing the suspension components / arch lining.
  5. #25
    Mar 2013
    Sydney, New South Wales
    Thanks for all your help guys. Ill look at an extra load 215/35 R18 and keep you all posted wih Taleb tyres decision on letting me swap or not and the photos and results!
  6. #26
    Mar 2013
    Name: TENZO-R TRACER V1 MATTE BLACK
    Sizes: 17x7, 18x7.5, 18x8.5 and 19x8.5
    Finish: Matte Black
    Stud Pattern: Multifit Stud Patterns
    Offset: +32mm up to +45mm
    Structure: 1 Piece Cast
  7. #27
    Oct 2011
    South Australia
    Nice Rims.
    I hope the tyre place is good about it.
    I'm surprised they sent you out with those tyres. If you roll in with your standard fit 17inch wheels with 40 profile tyre, why would they send you out with a rim an inch bigger but the same profile and think it keeps things fine?
  8. #28
    Jan 2009
    blankedy
    Finish: Matte Black
    Yeah, thats the range, you will need to know what your actual rims are.
    If your offset is too low or high, you will be restricted as to what size of rims you can run (if too low, you could consider spacing, but that has legalities to consider).
  9. #29
    Jan 2009
    Quote Originally Posted by sinclap2 View Post
    There is no such thing as a 215/35 R18 tyre with a load index of 87.
  10. #30
    Jun 2013
    Wagga Wagga
    Quote Originally Posted by Diesel_vert View Post
    Fair enough. I assume at is because they're not wide enough or not as wide as the 225's?
    Skoda Fabia vRS
