How can I check the offset used? I have the 18x7.5's
Printable View
Short Answer...
Google :-)
[ TENZO-R ] TENZO RACING SPORTS
This says they'd be et42 which looks about right from your photos.
Long Answer...
Pull one off and it'd likely be stamped on the back of a spoke.
A tyre's load capacity is related to how much air the tyre is designed to hold.
A smaller tyre isn't able to hold as much air, so naturally, it will have a smaller load capacity (as reflected by the smaller load index) and vice-versa.
Always keep in mind that it's the air that's supporting the vehicle - the tyre merely provides a medium in which to hold it. Think how much mass an uninflated tyre is able to support...
So I et42 a 215/35 will be okay with right tyre load?
The Polo GTI is originally fitted with tyres that have a load index of 87, which suggests that fitting a tyre with a load index of 84 (such as a 215/35 R18 tyre) wouldn't meet NSW roadworthy requirements.
As I said previously, it would be better to try a 225/35 R18 87V XL tyre first.
Considering the OE wheels have an offset of 46, an offset of 42 may be a small enough difference not to matter (which helps).
Thanks for being patient and it all the info mate!
Sorry for the dumb question, care there 215/35 with a load index of 87?
If 215/35/18 with load index of 87 existed it would be pretty near perfect?
You'll get it with a 225/35 though right? That's a more common fitment for that wheel.
Then you just have an aggressive offset. Which you have now anyway, but if that's only causing a small issue now with the 40 profile, a 35 profile will make that a little better.
