Tyre Rolling Diameter is the most important and brand/make of tyre is also relative as some have slight differences even in same size. Of course too wide and scrubbing can also occur.
So do the maths...
Old Wheel Diameter = 431.8mm (17")
Tyre Profile = 40% of 215mm wide = 86mm
Tyre Rolling Diameter = 431.8mm + 172mm (2 Profiles) = 603.8mm
New Wheel Diameter = 457.2mm (18")
Tyre Profile = 40% of 225mm wide = 90mm
Tyre Rolling Diameter = 457.2mm + 180mm (2 Profiles) = 637.2mm
So your tyres are more than 30mm too big in diameter... this is a fn disgrace from a Tyreshop, depending on tyre brand and type
Get it fixed and the scrubbing will very likely go.
As for tyre width...
215mm wide is 8.46"
225mm wide is 8.85"
but rim width to tyre width is not quite the same.
Most tyre shops should now the exact diameter of each tyre size in each brand and type, this is what you need to make the right choice. My diameter figures are a guide as there is a tyre bead to worry about too.
Size of original
