In terms of engine bay nuts.. mine looks the same as yours. So you're not missing anything there.
But my cowl sits flush on all the way along, drivers and passengers side.
Hi Guys,
After doing a routine engine oil top up today, I saw something strange, looks like there are two nuts missing in my engine bay. I also found that the driver side windscreen cowl is not sitting correctly, allowing dirt to sit inside.
I would appreciate if someone could confirm if I am missing two nuts in my engine bay, and confirm that their cowl sits flush with the windscreen. (The passenger side cowl sits nice and flush.)
Photos can be found on my skydrive: http://sdrv.ms/YMolf0
You will also see some soot images in there, collecting them for my next VW visit.
Thanks in advance, Andrew.
My new Jetta also had those screw plates missing, just bought 2 new ones from VW, 40c each... Simply screw on.
My engine bay looks the same as well - bar swapping the VW badge for a Skoda one.
Now gone.... 2012 Skoda Fabia RS
Thanks for the replies.
Hi Transporter,
I have tried multiple service stations using BP Ultimate, and I have consistent soot coming out the exhaust. This may also explain the high engine oil usage I am getting of approx 1L/1000km. I am happy to try different fuel to test the theory.
Holy Cow.
Greater than 1 L per 1000km is bloody shocking.
I wouldn't put up with that.
I had an old Alfasud with a very worn engine that burnt less oil than that and my mechanic had to put in the thickest oil available so it would pass the road worthy emissions test.
Honestly tell them you are not happy about it, and if it does not improve you want something done to rectify the problem.
Hi Andrew,
My MY13 Gti was missing the same fasteners after it cam back from a warranty repair 4 weeks into ownership. I think they removed the sound deadening on the firewall to fix the sound actuator dash board rattle. When I showed the service centre mechanic that there was a fastener missing and if he had a spare one laying around that he could affix to said area, he proceeded to crap on about how he would have to order one from Germany & I would have to book it in again. I smiled & told him not to worry. The following week when they gave me a loan car to fix a problem they made on the second visit back for repairs 4 weeks into ownership, I managed to find the parts I needed off that car. Problem solved, no need to order anything from Germany.
