Results 1 to 10 of 10
Thread: MFD Question
    Feb 2010
    MFD Question
    Forgive my ignorance, but the Golf I test drove I was able to access the menu in the MFD display, however I can't seem to find a way to do this on my Polo. Is this something specific with the Golf?
    Thanks!
    2020 VW Golf R
    brisbane
    shpould be a button on the wiper stalk underneath to change menus and the swith on the end of the wiper stalk to go up and down all in the manual depending on specs
    Feb 2010
    Quote Originally Posted by bushnut View Post
    There is a OK/RESET button under the wiper stalk, is this what you mean? When I press it, it doesn't go into any advanced menu
    2020 VW Golf R
    Feb 2010
    By the way, I am talking about accessing the convenience menu that let's you adjust delay's etc
    2020 VW Golf R
    Jan 2010
    Perth, WA
    Don't know if this helps but I just took the missus new polo into dealer to get the autolock features enabled as you cant do this yourself on the mfd - some things seem to be locked down to dealer access only.
    Feb 2010
    Quote Originally Posted by Grogmon View Post
    Thanks for the reply, are you able to get into the MFD menu at all though?
    2020 VW Golf R
    Jul 2005
    not sure if it has changed with the new polo but the previous models had no mfd like the golf. very limited info shown in the speedo digital section such as time, outside temp, average speed, instant fuel consumption, average fuel consumption, distance to empty etc... all this is accessible through the wiper stalk end buttons to scroll through them, the reset/ok button changes to the 2nd set of info (shown as a 1 or 2 in the upper corner of the digital display) if you press it once and resets all the info if you press and hold.
    its in the manual.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Jan 2010
    Perth, WA
    Quote Originally Posted by Allegiance View Post
    Only able to access things such as blutopless2 pointed out. Trip time, trip length, average and current speed, speed warning, average and current fuel consumption, outside temp and distance till empty.
    Seems like a dumbed down version compared to the golf MFD which enables you to set a lot more things.
    Maybe contact the dealer for more info because I'm sure if they can set things like autolock/unlock for you then they would be able to do time delay(for headlights etc)
    Jul 2005
    just to clear up any confusion i may have put in......
    the information is displayed in the tacho digital display... not the speedo as i stated above.... my bad.
    Feb 2010
    Maybe the MFD is only a basic one I like being able to play around with settings like that
    2020 VW Golf R
