Brains trust,
I've gone ahead and ordered the bits from the UK and Germany to retrofit the MDI to my GTI but I was looking through the spec sheet again and it seems to say the MDI is standard on the GTI?
Am I reading the spec sheet right and it was meant to be fit by the dealer and forgotten or am I reading it wrong?
Other GTI owners, please confirm
Link to spechttp://www.caradvice.com.au/wp-conte...-GTI_Specs.pdf
2010 Polo GTI - 5dr Flash Red
Completed upgrades: RNS 510 install, Retrofit MDI, Bluetooth
Planned upgrades: Amp, 3 way speaker install
Planned mods: APR tune, Brembo brake upgrade
2011 POLO GTI 3dr, Candy White, Audio-Comfort-Xenon PacksMODS: H&R Sport Springs - Bilstein B12s - Whiteline Sway Bar - Milltek Cat Back Exhaust - Sparco Assetto Gara Wheels
Nope, GTI JOE is right, no MDI standard. If it's retro fitted at the dealer, the poms are saying they buthcher up part of the inside of your glovebox to fit it. Hopefully you do a nicer job yourselfDid you make sure it works with the RCD310 standard unit in the Polo before ordering? Or did you order the RCD510 as well. Would be interested in teh costs as factory fit was a $500 option, or was that the $770? I think $770...
Yep, audio pack was $770 when ordered as an option
2011 Polo GTI - I have it, I Love It!!!!
Candy White 5 Door, Comfort Pack, Audio Pack - RCD 510, Bi-Xenons, Panoramic Sunroof
OK, thanks.
The spec sheet is a little misleading, it has an S against the MDI but I can see how it is "S" when you order the RCD510 which is an "A" for accessory.
I ordered the MDI unit from the UK and the piggyback, plug and play harness from Germany for about $180 all up.
I'll update my RNS510 install thread once done.
I plan to do the Bluetooth in the same hit, so it'll be a good day in the car once I get all the parts.
Maybe time to chuck a sicky!
I got the dealer to fit my MDI here before i bought it job was fine.
2010 Polo GTI 5dr, reflex metallic silver, MDI.
Now Replaced With
2012 Polo GTI 5dr, Candy White, Sunroof, Detroits
