Results 1 to 9 of 9
Thread: MDI - Maximum Size of Flash Disk - What does everyone use?
    Aug 2012
    Geelong, Victoria
    Hello everyone,
    I have just filled my 64gb USB Flash Disk with MP3 files and it works perfectly, after re-formating in Fat32 file structure.
    Initially, the standard Polo GTI Head Unit came up with a MDI Reading Error and would not work, until I used Fat32.
    Prior to this I had 32gb disk and that already had the same Fat32 File Structure.
    So I found and downloaded a 'HP File Conversion Application' and now the new 64gb works brilliantly.
    Unfortunately, it is now full, so I just purchased a USB2 (in a USB3 Case) 128gb Solid State Drive and put the exact same file structure (Fat32) and the same MP3's on it but it isn't working.
    All I get is "Media Initialising", for a few minutes when I get bored!
    Seems to have power to the case and I presume it is looking at the disc correctly as last time it came up with an error almost straight away.
    Any Ideas??
    Stephen
    Owner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
    APR Stage 2 Tune - HP Carbon Airbox - Jetex Stainless Cat Back Exhaust - APR I/C
    Plus a few other bits and pieces.
    May 2013
    Orange NSW
    RE: MDI - Maximum Size of Flash Disk - What does everyone use?
    I use a 320gb portable hdd with usb2. Works fine with fat32.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    Aug 2012
    Geelong, Victoria
    thanks Greg... mmm... hopefully this will work then... can't see it being any different, current draw is similar.
    Just a question... any idea how long it takes to read the file structure when you first plugged it in??
    Stephen
    Apr 2010
    Do you have all the songs in one folder or are they nested in different folders? The CPU in the HU will struggle if you have loads of tracks in the same folder.
    Also have you checked if there are any new MDI firmware updates on the mygti website?
    That said I'm still struggling to imagine how you have more than 64GB of music that you need to have on one disk (I would just label and swap USB sticks if it came to that, as I'm sure I could split them up by age or genre). To think that once upon a time we could hold around 15-20 songs on a cassette tape or CD
    May 2013
    Orange NSW
    I just noticed that you are using a USB3 case. That may have a bearing to why it doesn't work.
    Jun 2008
    Ringwood, Victoria
    1TB here and no issues...
    Aug 2012
    Geelong, Victoria
    thanks everyone... the case is USB 3 but the drive is USB2... i think. It is an SSD though so perhaps not.
    will clear one of my std USB drives
    Files are exactly the same as the USB stick too... same structure and size at the moment but I was going to add to it if it worked.
    Grrr that it doesnt..
    Stephen
    Jul 2011
    Also note that there is a maximum of 4096~ files that can be put in one folder. Also using USB3 will not be the problem because of the pin layout (6 small behind the front 4 large) means that its backwards compatible with USB2 connections.
    Also might be worth a check to see how much power the SSD is drawing. I'm pretty sure the MDI only puts out 500ma so if its trying to draw more it won't boot up.
    Aug 2012
    Geelong, Victoria
    thanks Nomadx38.... was told the SSD could be about 1amp but the power light does come up... just no noise! lol
    the files structure and numbers of them are all the same as the Memory Stick so that isn't it.
    The MDI can even remember the exact file (song) and position from the memory stick after the SSD has been plugged in and tested with no success.
    Quote Originally Posted by nomadx38 View Post
