Results 1 to 9 of 9
Thread: Low Coolant Level 2015 Poli GTI
    May 2015
    I'm out of town for a while over the holidays and today when checking the oil I noticed the coolant level is about 1cm below the minimum level on my 2015 polo GTI. The warning light also came on for a few minutes but has now gone.
    The car is booked in for its 30,000km service in about 3 weeks time. I went to Supercheap auto and saw a pre-mixed bottle of Nulon coolant, that was the only brand they had.
    Should I be topping this up or wait until the service is due at VW in a few weeks and is this brand suitable for the car?
    Is it unusual for such a fairly new car to be low on coolant??
    Dec 2008
    Sydney/Canberra
    I'd just top it up with water, and keep an eye on it, until the service.
    Have them take a closer a look at it, and get it pressure-tested.
    Jan 2016
    Quote Originally Posted by tomh24 View Post
    I had the same issue, bought the same coolant. Top it up youll be fine. VW dont give a ****, theyll just brush it off.
    Apr 2014
    The Monash Freeway
    My mechanic observed that the radiator was wet at the bottom. Coolant level was only very slightly down. Have it booked for an inspection by VW.
    Ben
    2015 Polo GTI & 2019 Golf R
    May 2015
    So I called VW and they suggested just top
    It up with demineralisd water. I topped it up to the min level, after getting home after about a 400km drive it has dropped again about a millimetre or two below the min level.
    I will have to get them to check it out at the 30k service in a couple of weeks
    Dec 2008
    Sydney/Canberra
    It does fluctuate a bit, depending on the temperature.
    Put it at the MAX mark. It will vent any excess coolant anyway.
    Dec 2014
    New Zealand
    Good advice ... it pays to avoid mixing coolants unless you are dead sure they are compatible. Obviously document what changes you see in preparation for the service, perhaps each day when the car is stone cold and avoid adding any more water if possible.
    May 2015
    Quote Originally Posted by Umai Naa!! View Post
    Thanks. Should asking them to pressure test it be included in the capped price for the service or do you think they will try and charge me extra?
    Dec 2008
    Sydney/Canberra
    The car is under warranty, so I'd imagine there would be no charge. Unless of course they find that the problem is not warrantable, such as a stick through the radiator.
