Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Lots of dash lights after checking horn fuse
  1. #21
    Quote Originally Posted by MIG View Post
    The speed data in the freeze frame is reported from the ABS unit, 255km is the value reported when there is no signal.
    @MIG: Hi.
    Yes indeed, you are 101% correct - but I very much suspect (hope really) that neither was the car traveling @ 255 KM/h when the module recorded the ABS signal loss!!
    I kind-of knew that the vehicle speed was wrong when I raised the matter because the freeze-frame data also says that when the car was supposedly traveling at 255 km/h, the engine speed was "803.50 1/min" (I think the units are meant to be revs/min). Of course this is near engine idle conditions!!
    As I know that you are aware from your programming work - 255 is a very special number because it is the the maximum decimal value that can fit into a hexadecimal pair! My hunch is that at the same time that the Airbag module lost the ABS signal, the signal for vehicle speed was also lost (probably because the vehicle speed signal comes via the same ABS module - via wheel rotation sensors ). I suspect that in this circumstance, the default value that is used in the vehicle-speed memory location for the Freeze frame data is hexFF - so what was recorded in the SCAN was the base-10 equivalent for hexFF (being decimal 255)!
    The airbag fault is due to the ABS unit being tied into the auto brake feature after a airbag deployment.
    Both faults are consistent with a loss of signal from the ABS unit.
    If I was working on this, I would be testing powers, grounds and the CAN signals at the ABS units connector. [
    Yes again - good opening suggestion!! But if indeed this is a genuine physical fault (yet to be poven)- the problem could also be CAN high/low wires on the Brake module
    Fact is without the Brake module reporting in the SCAN - both of our suggestions are mere conjecture!
    @Chruzz: I assume that you had no success with my ignition-ON, engine OFF suggestion. Maybe try a hard module reset by removing the negative battery lead for a while - then reconnecting!! If this also fails -can you get access to a VCDS cable?
    PS: @Cruzz - are you aware that you can get the wiring diagrams for this car from ERWIN. This document will tell you the pin-out for the Brake module (including power-supply, earth and CAN high/low wires and much more!). You will need to register but if you buy a one-hour subscription, you should be able to down-load ALL of the documents relevant to this car. Have you VIN ready and DON'T ask any on-line questions - your objective within the one-hour session is to down-load as many repair documents as possible (you can search through the material after the repair documents are resident on your computer). The wiring diagram is called "Basic Equipment" - I have no idea why!!
  2. #22
    May 2023
    Gold Coast
    Don, no luck with trying hard resetting by removing negative battery lead.
    I guess trying both the TSB suggestions on the software side and if that doesn't work start testing all the wires running to the Battery Control Module.
    I'm planning on taking it to VA Garage and book it in with them to see if they can fix it.
    OBDeleven vehicle history log
    Date: 2023-06-24 16:59:43
    VIN: WVWZZZ6RZHU016504
    Car:
    Year: 2017
    Body type: D5 Hatchback
    Engine: CJZC kW ( hp) l
    Mileage: 184810 km
    Full scan
    Control Units: 8
    Fault count: 17
    Control Units:
    17 Dashboard
    System description: KOMBI
    Software number: 6C0920730H
    Software version: 2310
    Hardware number: 6C0920730H
    Hardware version: 103
    Faults:
    U112100 - Databus missing message
    static
    Priority - 2
    Malfunction frequency counter - 1
    Unlearning counter - 175
    km-Mileage - 184810 km
    date - 2023-06-22 00:09:25
    44 Steering Assistance
    System description: EPS_TRW_ALow
    Software number: 6C2909144AG
    Software version: 3232
    Hardware number: 6C2909144D
    Hardware version: 323
    Faults:
    static
    Priority - 6
    Engine speed - 0 1/min
    Vehicle speed - 50.00 km/h
    System status - Driving mode
    Terminal 15 status - Terminal 15 on
    Voltage terminal 30 - 12.08 V
    Power steering current consumption - 1.34 A
    max.value - 30.44 A
    End stage temperature - 48 °C
    Steering assistance, engine output - 100.00 %
    Engine angle - 88 °
    Electric motor speed - 0 1/min
    Steering assistance, target engine torque - -0.54 Nm
    Steering torque - 0.04 Nm
    Status - OK
    date - 2023-06-22 00:09:27
    static
    Priority - 6
    max.value - 30.44 A
    Engine angle - 88 °
    Status - OK
    static
    Priority - 6
    max.value - 30.44 A
    Engine angle - 88 °
    Status - OK
    static
    Priority - 6
    max.value - 30.44 A
    Engine angle - 88 °
    Status - OK
    static
    Priority - 6
    max.value - 30.44 A
    Engine angle - 88 °
    Status - OK
    static
    Priority - 6
    static
    Priority - 6
    Voltage terminal 30 - 12.05 V
    Power steering current consumption - 1.35 A
    max.value - 30.44 A
    Engine angle - 88 °
    Status - OK
    date - 2023-06-22 00:09:32
    08 Air Conditioning
    System description: AC Manuell
    Software number: 6C0820045D
    Software version: 0203
    Hardware number: 6C0820045D
    Hardware version: H03
    Faults:
    static
    Priority - 6
    date - 2023-06-22 00:09:24
    15 Airbag
    System description: VW20Airbag00C
    Software number: 6C0959655K
    Software version: 0380
    Hardware number: 6C0959655K
    Hardware version: 002
    Faults:
    B13BCF2 - Multiple collision brake
    No function
    static
    Priority - 2
    Unlearning counter - 255
    date - 2023-05-31 10:18:03
    static
    Priority - 6
    date - 2023-06-22 00:09:26
    static
    Priority - 6
    5F Multimedia
    System description: MU-S--ER
    Software number: 3Q0035824B
    Software version: 0359
    Hardware number: 3Q0035824B
    Hardware version: H30
    Faults:
    static
    Priority - 6
    Dynamic environmental data - 028678186001
    U111100 - Function limitation due to missing message
    static
    Priority - 6
    Dynamic environmental data - 028678184402
    date - 2023-06-22 00:09:30
    01 Engine
    System description: R4 1.2l TFS
    Software number: 04E906027BB
    Software version: 9085
    Hardware number: 04E907309AF
    Hardware version: H23
    Faults:
    U012100 - Lost Communication With
    Anti-Lock Brake System (ABS) Control Module
    static
    Priority - 2
    Engine speed - 0.00 1/min
    Normed load value - 0.0 %
    Vehicle speed - 255 km/h
    Coolant temperature - 43 °C
    Intake air temperature - 26 °C
    Ambient air pressure - 1010 mbar
    Voltage terminal 30 - 11.991 V
    Dynamic environmental data - 209628105F0014CB00
    date - 2023-06-22 00:09:22
    19 Gateway
    System description: GW MQB A0
    Software number: 6C0909901A
    Software version: 0094
    Hardware number: 6C0937087
    Hardware version: H10
    Faults:
    static
    Priority - 2
    Supply voltage, terminal 30 - 12.0 V
    Terminal 15 - On
    Unknown ambient data -
    09 Central Electrics
    System description: BCM PQ26 Me4R
    Software number: 6C0937087D
    Faults:
    static
    Priority - 4
    Unknown ambient data - 050100788D
    Terminal 15 status - On
    Terminal 50 status - Off
    Voltage - 12.0 V
    Outside air temperature - 20.5 °C
    Status Bremslichtschalter (HW) - Off
    Status Bremslichtschalter (CAN) - Off
    Off - operated
    Parking light - not activated
    Automatic high beam assist - not activated
    Low beam - not activated
    Parking light left - not activated
    Parking light right - not activated
    Stoerschutzzaehler - 0
  3. #23
    @Chruzz: Bummer!!!.
    There appears to be many very odd aspects in your SCAN - not the least of which is the complete absence of ANY report about the Brake module, itself.
    I'm not sure if you are aware that the Gateway module in this car is the master module for the purpose of a SCAN - meaning that when you press the SCAN tab on the OBD11 software, it's the Gateway module that coordinates the challenge/response requests from the other modules (which populates the SCAN report).
    I'm also not sure if you are aware of the "GIL". It's the Gateway Installation List - which is a table that tells the Gateway module which other modules are installed in the car. The GIL is first established when the car is built - but it can be modified later when modules are added/removed. The Gateway module uses this list to identify which modules to poll when asked to produce a SCAN report.
    There are 3 x possibilities when a user asks the Gateway module to produce a SCAN report.
    Either:
    1. The identity of the module in the GIL aligns with the actual physical module that responds to requests, or
    2. One, or more modules are registered in the GIL, but they are NOT responding, or not physically connected to the CAN network (likely because the modules are NOT installed in the car)
    3. One, or more modules are actually physically connected to the CAN network, but they are missing from the GIL
    In ALL instances above, the SCAN report will identify the module status:
    • for 1 above, the SCAN will report the details shown in your SCAN reports
    • for 2 above, the SCAN will report that the offending module has failed to respond
    • for 3 above, the SCAN will report an error from the offending module(s) - being messages like " a module is requesting access - but not registered in GIL"
    My reason for explaining the stuff above is to emphasis that by deliberate design - regardless of status of a module (meaning, regardless of whether the module is powered, or not), the module will/should be reported in the SCAN report. But the Brake module is missing from this car, which is mighty odd!!
    Now, I assume that the offending Brake module is still operational - which makes me question whether the problem here is a power supply issue on the Brake module (no offense intended to @MIG suggestion). My hunch (wild guess really), is that initial signal loss fault as identified in the Airbag module has been subsequently exacerbated in some unknown manner by your earlier advice :
    "I ...disconnected Brake Control Module cable and sprayed contact cleaner on the terminals".
    It's not clear what were the conditions for the other modules on the CAN network when the Brake module cable was disconnected - but care should be exercised when disconnecting a central module such as the brake module. That said, please understand that my concerns about this matter are based on my ill informed understanding because there is much that is not known in this case!!
    Please keep me (us) informed - this is an interesting situation and I suspect that it will be a fascinating learning exercise (for me, at least)
