Originally Posted by
nomadx38
It's worth noting that VCDS sometimes incorrectly identifies the status of a given byte - as such on my 2011 polo, bulb checking is on for brake lights and indicators (and this is shown as an error on the dash when they are removed) but VCDS states it's not activated. When I change the bit to activate it - it is infact disabling it.
It's best just to play around with it
nomadx38: As I said in my post, I would have thought tha the lamp diagnostic settings would have been enabled as a default on my car- but they appear not to be. I guess that I tend to put a lot of trust in the stuff that the VCDS cable says- perhaps too much trust!
I assume that your 2011 Polo is also a 6R model. When you say that "VCDS sometimes incorrectly identifies the status of a given byte", is there any pattern to when it shows the wrong display (i.e. when does it mis-report the settings) ?
