Results 1 to 10 of 13
Thread: LED Parkers?
    Jun 2014
    LED Parkers?
    Are there any replacement led parkers available for polo gti that don't give the bulb warning?
    I have tried several canbus friendly replacements to no avail.
    Can I disable the bulb warning through vcds?
    Dont waste money on ebay jobbies - they are basically all junk.
    Bold Sport have good quality LED bulbs (several versions of T10) and they do not give you an error.
    Jun 2014
    Thanks.
    Sep 2009
    Mernda, Vic
    Jun 2014
    Quote Originally Posted by lush4 View Post
    Ordered....Thanks!
    Jun 2014
    LED T10's arrived from Bold Sport. Fit perfectly, no bulb error!
    Quote Originally Posted by Mardi View Post
    Mardi: I recently posted a table of the entire set of functions (all 24 bytes) for the central electronics (BCM -address 09) on the VCDS tread for the Polo 6R. From the table, it seems that the "lamp Diagnostics" functions can be found in Bytes 16 & 19. I've never played with these bytes, but logic dictates that these are the functions that control bulb warnings. Others here might know more about the lamp diagnostic function.
    It's interesting that no "lamp diagnostics" for any lights have been activated on my car (77TSI my14) but this may not be the same for other vehicles
    Anyhow, here is a screen shot of byte 19 which has the Tail lights (i.e. Parkers)- see bit 6. It might be worth checking your car to assertain if this bit is enabled
    LED Parkers?-09_polo-central-elect-19-jpg
    Jun 2014
    Thanks DV52.
    Jul 2011
    It's worth noting that VCDS sometimes incorrectly identifies the status of a given byte - as such on my 2011 polo, bulb checking is on for brake lights and indicators (and this is shown as an error on the dash when they are removed) but VCDS states it's not activated. When I change the bit to activate it - it is infact disabling it.
    It's best just to play around with it
    Jun 2014
    After fitment, they are close to the main beam. Are they likely to suffer from the heat?
