Dont waste money on ebay jobbies - they are basically all junk.
Bold Sport have good quality LED bulbs (several versions of T10) and they do not give you an error.
Are there any replacement led parkers available for polo gti that don't give the bulb warning?
I have tried several canbus friendly replacements to no avail.
Can I disable the bulb warning through vcds?
2 PCS T10 LED Super White Canbus Error Free Number Plate Light Bulbs | eBay
These worked for me with no issues.
Mark
Mardi: I recently posted a table of the entire set of functions (all 24 bytes) for the central electronics (BCM -address 09) on the VCDS tread for the Polo 6R. From the table, it seems that the "lamp Diagnostics" functions can be found in Bytes 16 & 19. I've never played with these bytes, but logic dictates that these are the functions that control bulb warnings. Others here might know more about the lamp diagnostic function.
It's interesting that no "lamp diagnostics" for any lights have been activated on my car (77TSI my14) but this may not be the same for other vehicles
Anyhow, here is a screen shot of byte 19 which has the Tail lights (i.e. Parkers)- see bit 6. It might be worth checking your car to assertain if this bit is enabled
Thanks DV52.
It's worth noting that VCDS sometimes incorrectly identifies the status of a given byte - as such on my 2011 polo, bulb checking is on for brake lights and indicators (and this is shown as an error on the dash when they are removed) but VCDS states it's not activated. When I change the bit to activate it - it is infact disabling it.
It's best just to play around with it
After fitment, they are close to the main beam. Are they likely to suffer from the heat?
