Results 1 to 9 of 9
Thread: LED Interior installation Instruction
    May 2009
    Hi guys,
    Has anyone changed their interior light-bulbs on their Polo 6R ? I bought a set of LED lights, but I'm not sure how to take the Plastic housing off in the centre front and rear.
    Any tips appreciated
    Thanks,
    Erwin
    LED Interior installation Instruction-imag0604-jpg
    LED Interior installation Instruction-imag0605-jpg
    Last edited by windyzz; 14-06-2014 at 03:23 PM. Reason: added photos & edited grammar
    500 x 100 max size on sig pics please!!
    Jul 2011
    Hey mate.
    For the rear light stick your fingers under the left side (facing the rear hatch) and pull down. 4 clips hold it in on the side. If you pull it from the right side there is a possibility that you will rip the wire out.
    For the front put your fingers under (from the top) the bent grey plastic (the piece above the light). And pull back. 4 clips hold it in from the side. Once that is off can unclip the light panel (4 black clips). Watch out for the wire which is towards the back.
    If your still unsure let me know and i can post some pictures
    May 2009
    Thanks man
    You're a legend!!
    I just did the two front map lights tonight
    I notice when I put it all back, even with all the doors closed and the switch set to its middle position that the two lights I installed were very dim but still on. Do you find the same thing? There is still a dim light even when all doors are closed and I lock the car (leave it parked) so for now I've turned it in the "off" position to avoid a battery drain.
    Any thoughts?
    Thanks so much again!
    LED Interior installation Instruction-lights-dim-jpg
    Quote Originally Posted by nomadx38 View Post
    Hey mate.
    May 2009
    Just found a thread with others reporting the same dim lights in auto mode that I mentioned
    LED interior bulbs dimly on when in 'auto' mode
    It is a bit worrying but apparently won't drain the battery unless I leave it for a few months...
    Still haven't decided whether to leave them in the auto or off position though. I do like the lights coming on automatically when I unlock the car...
    May 2009
    In light of the annoying side-effects/issues related to this mod (see above and below links) I've decided to go back to the oem yellow lights
    Help: Interior Lights Have Stopped Working
    Led interior light issue?
    Where to get non-LED bright white festoon bulbs?
    What a shame
    LED Interior installation Instruction-light-comparison-jpg
    May 2013
    Hervey Bay, QLD
    I did that but left the middle bulb near the rear view mirror standard OEM bulb and I have no issues.
    Harry
    MY15 RED Polo GTI 6C - with DA Pack
    Jan 2009
    Sydney Norther Beaches
    Having troubles with the front lights - With regards to the 4 black clips how do you release them and pull the lights out?
    Touareg V6 TDI MY15
    Polo 6R Comfortline MY15
    Touareg V6 TDI MY11 - sold
    Touareg TDI 2008 MY08 - sold
    Jan 2009
    LED Interior installation Instruction-img_3946-jpg
    These front lights (the ones in the centre of the roof near the rear vision mirror) are driving me crazy, I pulled off the curved plastic bit to expose the above and I have no idea what to do next. please help!
    Touareg V6 TDI MY15
    Jul 2011
    Quote Originally Posted by Hoodie View Post
    Pull the light panel out from the bottom. put your index finger on the panel - left bottom corner of your photo and put your thumb on the roof liner next to the panel and pull the light panel down towards the floor. Do this for every corner
