Results 1 to 9 of 9
Thread: LED foglight kit
    Jul 2012
    Coogee, NSW
    LED foglight kit
    Looking to install foglights into my base model polo, i found this kit on Oriental Parts
    LED Powered Front Fog Light Kit - Polo 6R - Oriental Parts
    What are your thoughts, and also is this install simple to do or should i get it done somewhere ??
    MY11 Polo Trendline, Candy white
    RCD510, R badge, AP X coilovers, 17" Ariettas in gloss black, Rear muffler delete, GTI pedal covers, gloss back emblems
    soon to come, Front lip & Fat bottom steering wheel
    Pacific Paradise QLD
    My thought is that they are a waste of money seeing that you can only legally use them in "FOG"
    Am sick of being blinded by people with really bright flared "Wanker lights"
    Jul 2011
    I could be wrong to think this but do you want to use these as DRL (daytime running lights) or do you seriously want LED fog lights.
    Keeping it simple: halogen bulbs offer much better light on the road compared to standalone LED’s. (The only exception is a high powered LED in a projector housing).
    If you wanted DRL there are cheaper alternatives out there.
    Jul 2012
    Coogee, NSW
    Quote Originally Posted by nomadx38 View Post
    Yeah I do want them as DRLs but also at night in combination with normal lights. But I dunno if that combination is achievable. The oriental parts do another kit that is non LED.
    Oct 2011
    Atwell, WA
    Quote Originally Posted by Nuggos View Post
    Not sure about the laws in NSW... But using fogs at night when there is no fog will get you picked up by the cops... I've been there done that many years ago and wore the fine... Better off just getting better globes for your main lights and leave the fogs alone
    2012 Volkswagen Polo GTI (Shadow Blue) | Current Upgrades - APR Stage 2 Tune | GFB DV+ | HP Cold Air Intake | OKADA Plasma Direct Coil Packs | HP Exhaust | HP DQ200 Tune | Whiteline Rear Sway Bar | Uprated Engine Mounts Planned Upgrades - | Coil Overs | HP Intercooler |
    Jul 2011
    @Nuggos
    Ok so if you are using them as DRL they are fine, it's completely legal. DRL have to be under 1200 lumens (I'm pretty sure) where as standard halogen bulbs can be upwards of 1500. I would not worry about police picking you up for that. I have seen many cars that change the foglight bulb to LED and make the light stay on permanently to meet the european DRL regualtion (most volvo car and the skoda fabia RS)
    To set these up, I would just tap a wire from your parking lights in the headlight and bring it down. I would assume these are not pulling more than 20watt so you will be fine so long as you take out the w5w bulb in the acuall headlight.
    Through vcds you just change the setting to have parking lights allways on with terminal 15. This will make it so your parkers are on in every position of the light switch as soon as the ignition is turned on.
    Personally I would do this differently, I would get proper halogen foglights (which oriential parts also sell, and I bought) and use them as actual foglights as their real function is quite useful in the fog, and I would get the headlights from VW which have the DRL built in (which I also have) which are of much better quality.
    Jul 2012
    Coogee, NSW
    @Nuggos
    Thanks alot ! im now wondering maybe it is better if i just get headlights with DRL built in like from kufatec OR should or can i just change the current DRL globe which is quite yellow and replace it with a xenon bulb such as this
    Volkswagen Polo 6R 2009+ Error Free Side Light Bulbs LED | eBay
    Jul 2011
    Yeah if you wanted to you could just change the bulb, it's a standard w5w bulb so there are many replacements. I used to use Philips LED parkers in my original headlight before i changed them. They are 1 watt LED's so these are one of the brightest you can get, but it comes at a price.
    $40 for a pair
    Philips X-treme Vision LED W5W T10 6000k (Twin Pack) | Car Bulbs Direct
    This is where I bought mine from last time, the cheapest you will find as well, also free postage.
    Because you don't have a mfd in your car any change of bulbs will not throw up an error.
    Jul 2012
    Coogee, NSW
    $40 for a pair
    so these are the side lights? and did they have a blue tint to them? also how hard are they to install?
    so many questions my bad
