Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 'Knock' when Reversing. VW say 'Brake pads moving in caliper, its normal"? Reallly?
    Sep 2012
    Quote Originally Posted by Veeduby View Post
    I have a sort of clunk sound when moving forward (frontish/drivers side). Happens only once per journey and always occurs after starting the car and moving forward for the first time.
    Would this be the same type of thing?
    I would say it's the same thing. The pads are always in contact with the disc, even without a foot on the pedal. 1st movement forward after going reverse will push the pads in the caliper if there is a gap. You may find the problem disappears after a pad change, if the new pads have finer tolerances in the caliper.
    Jun 2008
    Emerald, Vic
    Good to know that they are not trying to take the cheap way out (and do nothing). I'll pull the wheel off today and have a look.. It could even be an increased tolerance in the calipers casting?
    I appreciate the cause and its not hurting anything but I don't think that cars now a days should make any clunks, knocks or creeks as they have come so far in both technology and manufacturing compared to even 10 years ago (but I guess brakes have not chanced in that time)
    Would have been nice if vw had said "yes while it's not hurting anything and doesn't affect the operation of the brakes, hearing the clunk all the time is a little unrefined and not what we want a quality product like Volkswagen doing so we will change the brake pads for a different set"
    Like I say, car is brilliant and a sensational piece of kit, but little things can let down the rest of the package..
    Jul 2005
    Quote Originally Posted by pontiff View Post
    pmsl
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Jun 2008
    Emerald, Vic
    True.. What was I thinking
    Sep 2012
    What Op is talking about is putting brakes on when reversing which may shift the pads if they dont fit tight.
    Not the same as a noise when moving without the brakes applied
    I think you already posted about this ( or someone did) Could be a solenoid in the motor retracting as a noise like that occurs in my Polo when moving off when cold only
    Quote Originally Posted by staz88 View Post
    Thanks to both your responses! I guess I'll just live with it since it doesn't seem to be a big deal.
    MY12.5 Polo GTI - Pearl Black - Sunroof - Alcantara
