Results 1 to 10 of 15
Thread: 'Knock' when Reversing. VW say 'Brake pads moving in caliper, its normal"? Reallly?
    Jun 2008
    Emerald, Vic
    Hey all,
    For about 10k now my polo makes a 'clunk' noise from the front end when reversing into a car space. It only seems to happen on the drivers side and the clunk only happens once per movement. Sounds like a strut or swaybar knocking against something...
    I took the car to VW today for its 30k service and the service adviser just rang and said "it's the brake pads moving in the caliper and its perfectly normal"
    Does anyone have the same issue? Does what the SA is saying right? Ive never heard of that before...
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
    Sep 2012
    Sounds like a correct analysis. First movement in reverse after travelling fowards will make the pads move to the other end of the caliper if there is a small gap.. hence the clunk.
    My other car does the same thing.
    Feb 2009
    NSW
    Yep, MK6 118tsi- They said the same thing. I don't believe them as the pads are NOT supposed to move at all.
    Jun 2008
    Emerald, Vic
    Glad its not just me getting this problem then. Its just frustrating that the car is BRILLIANT in so many ways, yet silly little things like that where you go "what do you mean THAT is normal" spoils it somewhat. There is probably seating compound or something that would help which I will look at when I get the time.
    Incidentally.... 30k service (oil service and brake fluid change from what I can see) without the pollen filter... Barloworld Glen Waverley, $658. Will certainly be shopping around next time, that sounds a little steep.
    Oct 2012
    Perth WA
    I get the clunk in a B6 Passat but only when I have swung in an arc and then reverse, if drive in straight and reverse out straight I don't get it.....actually the 528 Beemer I had before used to do it ooccasionaly as well and I was told was normal....
    Jun 2008
    Ringwood, Victoria
    What?!?!?! Tis why I wouldn't ever go back to Barloworld along with the complete lack of knowledge.
    Sep 2012
    I have a sort of clunk sound when moving forward (frontish/drivers side). Happens only once per journey and always occurs after starting the car and moving forward for the first time.
    Would this be the same type of thing?
    MY12.5 Polo GTI - Pearl Black - Sunroof - Alcantara
    Pacific Paradise QLD
    Quote Originally Posted by Veeduby View Post
    What Op is talking about is putting brakes on when reversing which may shift the pads if they dont fit tight.
    Not the same as a noise when moving without the brakes applied
    I think you already posted about this ( or someone did) Could be a solenoid in the motor retracting as a noise like that occurs in my Polo when moving off when cold only
    Jul 2012
    Coogee, NSW
    Quote Originally Posted by pontiff View Post
    650 sounds right NOT, they seriously are retards. I have been to the dealer 3 times now to get rid of a noise which i keep being assured is "normal operation" which i was told by their mechanic it wasnt when he sat in my car, and last time they said they extensively tested it on the road yet the odometer didnt move, how amazing
    MY11 Polo Trendline, Candy white
    RCD510, R badge, AP X coilovers, 17" Ariettas in gloss black, Rear muffler delete, GTI pedal covers, gloss back emblems
    soon to come, Front lip & Fat bottom steering wheel
    Feb 2009
    NSW
    My last service was about $650 ish from CCC, I think it was the 30,000. My gf drives the car sod I'm not sure!
