Results 1 to 3 of 3
Thread: Jetta Hybrid
    Jetta Hybrid
    World premiere of the new Jetta Hybrid in Detroit | VWWatercooled Australia
    The interesting part is the drivetrain
    111kw/250Nm (1400-3500rpm!) turbo only 1.4L mated to a 7 speed DSG. Additional 20Kw electric motor.
    That gives you a power output equivalent to a Polo GTI.... hmmmmm I wonder if VW could make a hybrid Polo GTI?
    Mar 2011
    Netherlands
    VW is putting a hybrid Polo Bluemotion on the market in the future so who knows Might get way too heavy on the back end though so the car will have even less grip at takeoff
    Oct 2010
    Melbourne, VIC
    there is an electric-only E-mode that will propel the new Jetta for up to 1.2 miles
    WooHoo!!!!
    Why they don't do this with the diesel version is beyond me
    As for the Polo Bluemotion hybrid, it probably won't have enough power for the weight at the rear to be a problem (and it will help balance the car's handling)
    Resident grumpy old fart
