Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: ITG Maxogen Air Intake vs. HP Cold Air Intake
    Gold Coast, QLD
    That was my car. I have the graphs, but not sure I have the right to publish, so will leave that to Guy.
    The figure, completely stock, was 117.1 kW. Peak figures tell only part of the story, though, as clearly there are increases throughout the range.
    Not relevant to performance, but the HP Intake, aesthetically, is a work of art when installed. The Carbon Fibre is gorgeous.
    Edit: I confirm I only have the Stage 1 tune.
    Gold Coast, QLD
    Quote Originally Posted by gavs View Post
    Still disagree on the intake though
    Why would you disagree on the intake? There either is a hot air intake or there isn't... no?
    Oct 2011
    Atwell, WA
    gavs... based on your views on the 'supposed' performance gains would you buy the ITG or the APR/HP? or neither?
    2012 Volkswagen Polo GTI (Shadow Blue) | Current Upgrades - APR Stage 2 Tune | GFB DV+ | HP Cold Air Intake | OKADA Plasma Direct Coil Packs | HP Exhaust | HP DQ200 Tune | Whiteline Rear Sway Bar | Uprated Engine Mounts Planned Upgrades - | Coil Overs | HP Intercooler |
    Quote Originally Posted by Banana2 View Post
    I'd be interested to see your stock dyno run.
    @117kw peak sounds like a happy dyno tbh, my 1st GTI made 112kw on a tough dyno at HPF fyi as a comparison.
    Jun 2008
    Ringwood, Victoria
    I am continuously logging (when my laptop is charged) what my intake temps are and as I said, a difference of 1-2 degrees over ambient. At rest, yeah the heated radiant air from the radiators would creap into the intake but once moving, I struggle to believe that 50% of the cubic volume of air being sucked through the MAF and intake temp sensor can be cooled that much without seeing the data that shows where that half of the volume is coming from. All intake temps will creap up at rest, especially after driving. Engines work as a vacuum and suck air into them, logic dictates (and is proven by race teams the world over) that the best place for an engine intake is at a point of high air pressure and the highest air pressures are found at the base of the windscreen and at the front bumper. That high pressure air is much easier to be sucked in compared to the area of low pressure behind the radiators which is the area of heated air. But hey, that's just me and data from several days of heat and pressure testing of radiators and intercoolers and the effect on the motor of the vehicle being tested.
    For the money being asked, would I personally say either or any aftermarket intake is worth the coin? Nope. I am a strong believer in retaining the use of OE filters as they are filtration tested to a spec and in the last 10 years I am still yet to see empirical evidence that an aftermarket filter (other than direct OE replacement) can filter as well. If you're chasing big power gains then I'd say go for it and yes, the HP unit really does look spectacular and is proven to flow better and provide more power to a tuned car, but would you see the same gains on a stock car?
    Gold Coast, QLD
    Quote Originally Posted by Gambit View Post
    I will leave it to Guy to comment about why the baselines might be different. It shouldn't be surprising that there would be differences between cars, at baseline, though. As well as differences between dynos.
    Regardless of the baseline, I'm guessing the gains would be pretty accurate. Guy did mention that his (our?) graphs show an average over a few runs, too.
    I see what you're saying, now.
    Getting a good baseline on a stock Polo is difficult, under dyno conditions, the stock intercooler will heatsoak dramatically, even when setting the road speed before a power run.
    ~ 100kw at the front wheels is what you would normally see if you can keep the IAT below 55 degrees, it will drop off every run and you can hit ~ 90 degrees after a few pulls, that brings the front power down around another 25kw (yes, as low as 75 kw when hot). If you can get a good cold run in with IAT's under 30, you can see another 10 - 15kw on top.
    Funnily enough, it is the exact same problem as the Side mount intercoolers have on the old Polo 9N.
    Gav's, part of the effect of capturing 100% of the cold air feed would be the ram effect, its now a pressurised intake as the "escape" path, or "Hot Air" feed is blocked off, forcing the lot into the mouth of the intake.
    Nothing wrong with ITG intakes either, we have sold a heap of them for a different specific application. They make a good unit.
    Jun 2008
    Ringwood, Victoria
    Guy, sorry if I sounded a bit, well, rude about it, that was not my intention. After you explained the theory of the hot air feed I understand and agree that yes, there is an element of hot air being drawn into the motor at rest, it just reads like the website is saying that the air intake is a hot air fed intake, like an old commodore motor or something, not as in a pre-heater for the intake air when the vehicle is traveling slowly/at rest. I'm not saying or suggesting you alter the copy on the website as that's not my place, it's just a little confusing for those of us who know the vehicle fairly well, for the average punter though it reads as it should IMO.
    Jun 2008
    Ringwood, Victoria
    Side note, you're selling the VW Motorsport/Racing intakes yeah, being the licensed importer? It is just the ITG intake is it not?
    VWR (Volkswagen Racing or Racing Line) contract ITG to make some intakes to their design & specifications, the Polo version in question is not available to us at this stage.
