Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Interesting torque figures for 7Spd Dual Clutch
    Jun 2008
    Ringwood, Victoria
    Now, straight up, I don't know if the gearboxes are the same but seeing as the more powerfull 125TDI motor can only be had with a 6spd manual, I have my suspicions that they are very similar to the polo GTI gearbox...
    This is from Drive.com.au about the new Tiguan
    New VW Tiguan (launch drive models only)
    155TSI
    Engine: 2.0-litre turbo 4-cyl
    Power: 155kW at 5300-6200rpm
    Torque: 280Nm at 1700-5200rpm
    Transmission: 7-spd dual-clutch auto
    , AWD
    Fuel consumption and emissions: 8.6L/100km and 199g/km
    0-100km/h: 7.4 seconds (claimed)
    125TDI
    Engine: 2.0-litre turbo diesel 4-cyl
    Power: 125kW at 4200rpm
    Torque: 350Nm at 1750-2500rpm
    Transmission: 6-spd manual
    , AWD
    Fuel consumption and emissions: 6.0L/100km and 158g/km
    0-100km/h: 8.9 seconds (claimed)
    132TSI
    Power: 132W at 4500-6200rpm
    Torque: 280Nm at 1700-4500rpm
    Transmission: 6-spd manual or 7-spd dual-clutch auto
    0-100km/h: 7.9 seconds (auto, claimed)
    Seems the first admission that the 7spd Dual clutcher can indeed handle more than the supposed limit of 250Nm.... I noticed today also the new A1 Sport has 4 more kilowatts of power over the GTI, yet somehow has exactly the same torque figure.....
    Oct 2010
    Melbourne, VIC
    There is an older spec 7 speed DSG that has a lower torque limit than the new one.
    I think the Polo uses the older one to save on costs (but I could be wrong)
    Feb 2009
    Sydney, Australia
    Sorry... you're both mistaken.
    There are two 7sp DSG gearboxes... this has been discussed before, so I'm just going to copy and paste what I wrote then:
    There are only 3 DSG models (in order of release).
    1) 6sp wet clutch 350Nm
    2) 7sp dry clutch 250Nm
    3) 7sp wet clutch 550Nm
    The "Original" DSG was the 6sp wet clutch DSG. VAG rate it for 350Nm and it has FWD and AWD versions.
    Later came the 7sp dry clutch DSG. VAG rate it for 250Nm and it was designed to greatly reduce maintenance cost, weight etc.
    Then came the 7sp wet clutch DSG from Audi. VAG rate it for 550Nm. It's said to be very similar in design to the 7sp PDK which Porsche designed and commissioned VF to build for them. It's a monster of a gearbox though...
    The two 7sp gearboxes couldn't be further apart. The 7sp dry clutch weighing 70kg with two single plate dry clutches and having a transmission oil system with only 1.7L. The 7sp wet clutch weighing 140kg with a 10 plate clutch and a 12 plate clutch. It then has two separate transmission oil systems. A 7.5L system which lubricates the clutches and mechatronics. And a 4.3L system which lubricates the gears and differentials.
    So it's not a case of there being an "older" and "newer" 7sp DSGs. They're COMPLETELY different gearboxes which are engineered for completely different purposes. Considering VW couldn't fit a 6sp manual gearbox into the Polo GTI, there is no way that the 7sp wet-clutch DSG could fit in the Polo GTI. Also, with the weight penalty, you probably wouldn't want it to!
    May 2011
    QLD
    I think the OP is aware of this.
    But I did recall there was a newer DSG 7 speeder designed for their turbo diesel vehicles and given the price range, it's unlikely to be the monster version used in the Audi ones.
    Ps wouldn't the modded R DSGs in danger of busting the limits if the gearbox?
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Corey_R View Post
    Where am I wrong????
    The older 7 speed DSG has a lower torque limit and is cheaper (and is lighter/smaller) than the newer one. I never said the designs were similar but they are both 7 speed and DSG
    Quote Originally Posted by DoggieHowser View Post
    IBut I did recall there was a newer DSG 7 speeder designed for their turbo diesel vehicles and given the price range, it's unlikely to be the monster version used in the Audi ones.
    Yes it is an it is only used in the bigger turbo diesel vehicles. That's why the Golf/Jetta use the 6 speed DSG.
    The turbo-diesel 6R Polo is relatively gutless so the older 7 speed DSG can handle its output.
    That'd be gavs's concern
    May 2011
    QLD
    Adelaide hills, SA
    The Audi Q7 and Q5 has the 7sp longitudinally mounted DSG and it is very long g.box shorter version of it is in new T5's and Tiguans from MY11. It's very unlikely that any of the 7 speed DSG with wet clutch would fit in the Polo.
    Oct 2010
    Melbourne, VIC
    Yep, it's studded with references about how the DQ500 is designed for larger vehicles
    Adelaide hills, SA
    You can find more about the Q5 and the DSGbox in this link. AUDI_Q5_Eng_Trans[1].pdf
    Adelaide hills, SA
    If anyone is worried about the life of the DSG, then I suppose he/she is right that the limits set by manufacturer will be exceeded.
