Originally Posted by
GtiDave
2yr service is most likely 30k yeh?
Air filter normally isn't done till 60k at dealer
If you buy 1L brake fluid, that's more than enough.
Most dealerships will only drain half that during the job. I've even seen guys sucking out the brake fluid reservoir and refilling it without bleeding the brakes at all when time's are tight.
That's the way stuff happens sometimes.
The only problem with DIY is resale value, because unless you're buying off a mechanic with receipts for parts, it's too risky for most buyers.
Air filter is done every 45K.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
