Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 65
Thread: How to deactivate daytime running lights?
  1. #41
    Quote Originally Posted by steveyoshi View Post
    wow...this has me confused.
    so you can not upgrade the globes in a xenon headlight vehicle?
    gota bit to learn about my new car that is on it's way.
    No, Nomad was saying that you can't put a xenon globe in a reflector housing on the low beam (because the DRL low voltage would destroy the bulb).
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  2. #42
    Mar 2013
    Melbourne, Victoria
    Quote Originally Posted by nomadx38 View Post
    There are many options to choose from:
    If you have foglights you can swap the DRL functionality from the low beam to the foglights and change the bulbs to white ones or high powered LEDs or what ever you choose.
    You could also change the low beam bulb to a philips blue vision ultra or something a bit more white. (Not xenon, the low voltage on the TFL terminal will destroy the xenon ballast. Also xenons in reflector = BAD!
    You could also disable the low beam DRL via the TFL terminal and change the coding to always have the parking lights on (terminal 52 on with ignition) and change the parker to a high powered LED - this would emit less light than the other options but its better than nothing.
    Don't have foglights... just to confirm that's just a simple 'heatshrinking' of the TFL terminal as mentioned before? No need for 'vagcom' coding?
    2013 Polo Comfortline | 77TSI DSG | Candy White
  3. #43
    Quote Originally Posted by Drooberius View Post
    If you don't want any lights on when the headlight switch is set to 'off' then no coding is necessary (just the TFL pin heat-shrinking/bending/removal).
    Coding is only necessary if you want to have your parkers on when the headlight switch is set to 'off' (for extra safety).
    Alex Aescht
  4. #44
    Mar 2013
    Melbourne, Victoria
    Quote Originally Posted by alexaescht View Post
    Thought that TFL mod is just for headlights as per post #4... parkers, rear & plate lights still on?
  5. #45
    As far as I know, in Australia only the front, reduced voltage low beam headlights are used for DRL purposes, without the number plate and rear lights on.
    Although I could be entirely wrong.
    EDIT: Sorry, just read over the earlier posts again and yes, some coding is necessary as the front and rear parkers and number plate lights will stay on after the heat-shrinking of the TFL terminal.
    Alex Aescht
  6. #46
    Mar 2013
    Melbourne, Victoria
    Yup... just did it today - very simple... 3rd terminal from the left with a bit of heatshrink (TFL - although I think it's actually terminal 56). No headlights, but park, rear and plate lights remain on - which is fine by me. Will be changing globes later down the track.
  7. #47
    Jul 2011
    Hmm interesting. Most Coding in VCDS involves the use of terminal 56. I wonder if this will effect any coding later down the track.
    Just from memory i know the Xenons DRL use terminal 56 to operate and the ability to use the indicator stalk for specific parkers also runs independently from the "parking" light position, again running off the status of terminal 56...
  8. #48
    Mar 2013
    Melbourne, Victoria
    TFL/56 ?! Lets just call it third from the left as per picture in post #4. Coding required as Alex says to do more.
  9. #49
    Singapore
    You have to change the setting in Cent. Electrics which "Dim LED DRL on terminal 85 (which is the parking setting)" or something like that. It's in the same sub menu which dims LED DRL when indicating.
    I was told that LED DRL have to be dimmed on the parking/low beam setting because when they are used in conjunction with the low beam the light output exceeds ECE standards.
    Me personally I have them on full all the time 'cos they look cool.
    Anybody have the excact procedure? I cant find it to work right. I want it to be fully lit up and not dim down. Thanks
  10. #50
    Pacific Paradise QLD
    Quote Originally Posted by kevinctr View Post
    Saw somewhere yesterday that it is illegal to turn them off or alter them
