Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 65
Thread: How to deactivate daytime running lights?
  1. #51
    Jul 2011
    I think he is talking about the LED's. and it could be counted as legal as my dads Hyundai i40's LED DRL do not dim with the indicator.
  2. #52
    Pacific Paradise QLD
    Quote Originally Posted by alexaescht View Post
    As far as I know, in Australia only the front, reduced voltage low beam headlights are used for DRL purposes, without the number plate and rear lights on.
    Although I could be entirely wrong.
    EDIT: Sorry, just read over the earlier posts again and yes, some coding is necessary as the front and rear parkers and number plate lights will stay on after the heat-shrinking of the TFL terminal.
    Passat has separate LED DRL's front only, would like rears on as well
  3. #53
    Apr 2013
    Can't turn off my rear tail lights?
    Quote Originally Posted by kam View Post
    why did vw setup the headlights like this on the polo anyway ?
    the 'off' position, when driving, turns the headlights on, which is silly, so i always turn it to the middle position to turn the headlights off when driving, and then when parked, put it back to the left position to turn them off.
    Picked up my GTi a few days ago NO PROBLEMS so far except this one - with the light switch in the O (off) position the main rear tail lights (+number plate light) are ON. The day time driving headlights (non halogen) are on as well which I am happy with but not happy that the main tail lights are on. Only way I can get the tail lights off is to turn off the ignition.
    Re kam's post above with the switch in the middle position (parkers) the main tail lights are on which is not what I want during the day.
    Is my issue a vadcom coding one or has anyone else had this issue?
    Love this car!
  4. #54
    May 2012
    Quote Originally Posted by car_nut View Post
    Love this car!
    Why are you happy with the front on but not rear? Makes no sense.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
  5. #55
    Love this car!
    I am pissed because the rears dont come on with the fronts Just as important to be seen from the back as the front.
    Why worry You cant see them when driving and anything to help being seen is an advantage.
    As already said they are compulsory in some countries and should be here as well..
    No more idiots driving at dusk with no lights on.
  6. #56
    Apr 2013
    Quote Originally Posted by lunchboxGTI View Post
    Fronts on it's obvious and most of us would agree - be seen, I have too often heard >"but I did not see him/it/you"
    Rears on - might be good in a heavy fog or rain, otherwise?
    Is it standard for the rears to be on all the time?
  7. #57
    Apr 2013
    like that one
  8. #58
    May 2012
    Yes it is standard.
    Your contradicting yourself. "Have the fronts on to be seen" but then you say who cares about the rear on. It's the Same concept rears on to be seen.
    Idiots especially in black cars right on dusk Pull out in front with no tails on and make it hard to see them. I have no problem with people who obey the road rules and drive normal not having tails on as I know they are there and leave space. It's the idiots swerving all over the place and cutting you off just to gain one 2m (we all know the ones) in low light that that cause issues.
    If there design to come on just leave them that way. If your worried its going to prematurely wear out your globes then sell your car.
    because compared to the cost of purchase and ongoing maintenance over its life some 50 cent globes are just a drop in the ocean.
    I can understand wanting things on when there not but trying to turn of things that where design that way is pointless. Why not direct your attention to something worth while.
    If you want to run LED,s in your tails/headlamps without the errors get some of these.
    http://www.narva.com.au/products/bro...-load-resistor
    I have led brake globes with these and they work fine with no errors.
    MY12.5 Polo 6R GTI
  9. #59
    Jan 2008
    I'm a sensible adult & want to be able to turn my headlights off if necessary!
    I've been spoilt by 7 years of auto-lights on the MkV, but there's always a case when you want to manually turn the lights off (working on the car with the key in ignition, manually turn off headlights & interior lights to save battery drain)
    That said, totally agree with DRL's as an always-on feature, which is great in a car with proper LED DRL's - just a pity they're using the main halogen lights in the Polo & not the parker lights instead (or some retrofitted LED DRL's in the bumper).
    I agree that having the tail lights on permanently isn't ideal, but don't see a major issue with it - but there's no point in having the license plate lamp on the whole time.
    Anyone care to summarise the 6 pages of arguments & let me know the codes to turn the rear license plate lights on or off? and if it's possible to move the DRL function to the parkers (for headlight 'off' position).
    2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
  10. #60
    Jul 2011
    Haha by turning off the DRL in any form means that you are irresponsible! Haha just kidding - please take that as a joke
    Now what you would have to do is rip out the TFL pin on the back of the headlight switch as this function is hard wired in. That will deactivate the DRL using the main halogens.
    Then with VCDS go into cent electrics and go "adaption". There will be an option "parkers on with terminal 15" (terminal 15 been the 0 position on the light switch with the ignition on) this will light up the front and rear parkers!
    Enjoy
