Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 65
Thread: How to deactivate daytime running lights?
    Nov 2012
    Wagga Wagga, NSW
    Did mine yesterday by covering the TFL pin. 5 min job. Easy!
    Italy, Piemonte
    Quote Originally Posted by fontana302 View Post
    I'd like to see a wiring diagram as I want to totally turn everything off with the light switch off. By removing or shielding the TFL terminal, you only disable the main beam, you still have the front parking light, rear tail light & number plate light on, so essentially this is parking lights with dash lights off.
    To deactivate plate light you have to disconnect also pin #6 (grey/blu wire) -> may be different with right hand drive? To be verified...
    To deactivate parking light you have to change to 0 the byte 12 on long coding module 09.
    Oct 2012
    Many thanks kawabanga,
    Deactivation of parking light works exactly as you describe, make bit 0 of byte 12 not active on long coding module 09 (central electronics control unit) - just made the change. I changed this prior to disconnecting TFL pin & made no difference, so the two go hand in hand. Will verify pin #6 to finalise what I am after as you describe plate light is still on.
    Oct 2012
    Just confirmed what kawabanga stated. For halogens, to turn off all lights with headlight switch in off position:
    Make bit 0 of byte 12 not active on long coding module 09 (central electronics control unit) with VCDS, Disconnect TFL & pin#6 (either remove, bend tabs or cover with heat shrink).
    Apr 2012
    This seems very confusing for me... is there an easier way to explain it? What TFL and pin#6?
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
    Aug 2011
    Quote Originally Posted by Bassik View Post
    It's all spelled out throughout the thread? Just read all the posts
    Apr 2012
    Covered the TFL PIN today and voila... No Headlights in the "O" off position.
    Singapore
    Anybody knows how to set the LED DRL to not dim down when the HID lamp are on?
    Pacific Paradise QLD
    Quote Originally Posted by kevinctr View Post
    Why would it matter you cant see them when the Headlights are on anyway Presuming by HID you mean headlights and not "fogs"
    Jul 2011
    You have to change the setting in Cent. Electrics which "Dim LED DRL on terminal 85 (which is the parking setting)" or something like that. It's in the same sub menu which dims LED DRL when indicating.
    I was told that LED DRL have to be dimmed on the parking/low beam setting because when they are used in conjunction with the low beam the light output exceeds ECE standards.
    Me personally I have them on full all the time 'cos they look cool.
