Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: How to avoid front wheel spin
    Quote Originally Posted by osman View Post
    ok will take the advice on board. What tyres would you suggest? Currently running the stock Dunlop's
    Bridgestone Potenza ? is it an option?
    It will make little or no difference.
    You just need to use less throttle to start off and then feed more throttle in as your are moving. Like any auto, sudden large changes in throttle confuse the heck out of them.
    Jan 2009
    I have had the Polo GTI for a week now and if I my press the accelerator half way during takeoff I get wheel spin on the front two tyres. Traction control is on and tyres are new.
    Any ideas on getting a quick takeoff without wheel spin?
    thanks
    How to break in your tyres: Tire Tech Information - Breaking In Your Tires
    This advice also applies to brand new cars with less than 500 km to 1000 km.
    Contrary to popular belief, a vehicle's stability or traction control system, although very effective in assisting the driver, does not make the vehicle immune to the laws of physics, so you can only rely on it up to a certain point, as it can only do so much. Vehicle control (or loss thereof - accidental or otherwise) is ultimately the responsibility of the driver.
    I used to drive a Toyota Camry. I used to absolutely floor it but no wheel spin.
    How am I supposed to get a quick take off if I only press the accelerator down partly?
    Anyone can simply mash the throttle and spin up the tyres, if the vehicle is capable of doing so.
    The Polo GTI is such a vehicle, and is hardly unique in this aspect.
    As with any performance car, you need to readjust or learn how to regulate the throttle input in a more precise manner.
    Have fun.
    It would be better to re-evaluate the tyres after they've covered some distance, as per Tire Rack's advice.
    May 2013
    Sydney NSW
    interesting read this mate
    Jun 2011
    Sydney NSW
    Quote Originally Posted by lunchboxGTI View Post
    Practice. You need to get it in motion before you can floor it. Or by wider rims and get better quality tires.
    Actually wider tyres will not help unless the rubber compound has a higher coefficient of friction.
    You can have two tyres on each end of the same axle where one is wide and the other narrow. As long as they both have the same rubber compound, you will find that both will provide the same resistance to slipping. Why racing tyres are wider is because they are made of a softer (partially cured) rubber compound, and the width is to reduce the amount of wear. This is all what F1 is on about now.
    The equation of friction is F = uN where F is the force that can be generated between the two surfaces, u is a non-dimensional coefficient of friction, and N is the force normal to the friction surfaces. The trick is to keep the force to a level so that the torque from the engine does not exceed the friction between the tyre and road surface.
    Some cars will not break traction because for various reasons the force generated is always less than the friction force.
    You can get "better quality" tyres, however to get a higher coefficient of friction, the compound will generally wear more easily and so have a shorter service life.
    Everything is a trade off. That is why I suggested not pressing the accelerator as far. Just as you have a bite point with a clutch, you also have a bite point with the tyres as well. You need to feel for that and you are then getting the maximum accelerating force you can.
    Jul 2012
    Coogee, NSW
    Quote Originally Posted by wai View Post
    God i hate physics at uni currently, but it has so many good uses!
    Nice explanation wai, clearer than most 90 year old lecturers lol
    MY11 Polo Trendline, Candy white
    RCD510, R badge, AP X coilovers, 17" Ariettas in gloss black, Rear muffler delete, GTI pedal covers, gloss back emblems
    soon to come, Front lip & Fat bottom steering wheel
    I'm surprised you didn't find out how easy it was to spin the tyres on your test drive.
    Mar 2011
    Netherlands
    Get these and see if you still have wheelspin
    Toyo R888
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Nuggos View Post
    One of the sad things is that you struggle through uni with all the information you are bombarded with, and then you start working and applying things and it strikes you. That is what they meant!!! Life would have been so much simpler if it came to you when they were teaching you .
    I find I get much better launches with tc off. It cuts in with minimum wheel spin when its on and cuts power. With it off you get a little slip but it usually grabs pretty quick. Different story when tuned though ha.
    Jan 2011
    Gold Coast, QLD
    What are you doing anyway, robbing a bank?
