Hi all, The horn has stopped working in my 2011 1.2 tsi
I suspect it is the relay or actual horn, as the steering wheel clicks when pressed.
Checked the fuses are ok.
Does anyone know where the horn relay is, I cannot spot it anywhere !
and how to get to the horn itself.
Thanks guys.
If you have access to a scan tool, you can check the measuring valves for the horn button and do an output test of the horn.
Most cars have duel tone horns, so if both stopped simultaneously, I would first look at the relay or a clockspring failure.
A erWin Online 1 hour sub will get you all the wiring diagrams \ workshop manuals.
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
