Results 1 to 6 of 6
Thread: HID in high beam
    Dec 2005
    Rockhampton Qld AU
    HID in high beam
    Has anybody thought about or actually put HID H7's into the high beam on their polo?
    I do a bit of highway driving and want some extra light but am not that keen on extra spotties.
    I was thinking about doing it to my Touareg as well.
    Neil
    '11 Polo TDi auto, White, Sunroof
    '91 Transporter syncro camper
    Dec 2012
    Sutherland Shire, Sydney
    It's not normally done because HID's don't like being turned on/off often
    If you have dual headlight bulbs/projectors then HID's on the low beam will remain on when you turn hi beam on - so you will will still have the HID benefit even when using high beam
    Dec 2005
    Rockhampton Qld AU
    Thanks Martin.
    No projectors here.
    I think that I'll give the 65w Osrams H7 globes a go in the high beam.
    There are a lot of 4WDers out there with HID spotties!
    Neil
    Dec 2012
    Yeah - the Rally headlight - it's meant to be awesome
    Pacific Paradise QLD
    HID spotties are legal HID headlights retrofits are not unless they have levelers and washers
    Jan 2009
    There is no requirement for automatic headlamp levelling and cleaning devices to be fitted for the main beam (i.e. high beam).
    That aside, retrofitting any bulb into a headlamp housing which it isn't designed for would not be considered roadworthy by most authorities.
