If the bulb light is alight on the dash you may need to clear the fault codes to get it back to working properly.
Also the boot light has a tendency for the contacts to go loose and not hold the old bulb properly after you put in a after market globe.
There is also a diode in the boot light holder which can blow very easily causing the lights to flicker. You will need a multi meter to check it.
The led's will flicker on starting the car and they will slightly stay on all the time unless you replace one of the front bulbs with a normal bulb.
