Results 1 to 7 of 7
Thread: Help Identify part where coolant is leaking
    May 2023
    Gold Coast
    Could some please identify this part of where coolant seems to be leaking from. See attached pics.
    Any further advice welcome
    Help Identify part where coolant is leaking-img_0740-jpgHelp Identify part where coolant is leaking-img_0741-jpg
    Dec 2008
    Sydney/Canberra
    Clutch slave cylinder.
    It won't cause a coolant leak.
    That housing on the end of the cylinder head with the spaghetti of coolant hoses coming out of it, is a likely culprit.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Pacific Paradise QLD
    Whats the pink crap to the right looks the color of coolant
    Nov 2007
    Yes, and a very different colour to the fluid that is in the clutch slave cylinder ....
    May 2023
    Gold Coast
    So more likely the water pump? Is that the spaghetti you referring to?
    I believe he is referring to this bundle of hoses (circled in green) which appear to be coolant hoses going into some kind of plastic junction. If im not mistaken, it looks like a small amount of coolant where I have put the green arrow, which is probably dribbling down and then pooling on the gearbox where you can see the bulk of the pink dried up coolant.
    You need to have a good look around that area with a torch and confirm where the leak is coming from.
    Help Identify part where coolant is leaking-2023-06-01-13_08_36-help-identify-part-where-coolant-leaking-jpg
    May 2023
    Gold Coast
    Thanks @Lucas_R
