Results 1 to 5 of 5
Thread: HELP: I have a headlight issue
    Sep 2018
    Hi All,
    I have a 6R 77tsi sports pack. Halogen lights with DRL.
    I have no low beam, (dipped beam).
    Start the car and only the parking lights are on. Rotate the lights selector switch 2 clicks to the right and still no low beam.
    The high beams work as expected. You can flash the highs buy pulling the stalk in when the light switch is all the way to the left and the high won't stay on when you push the stalk forwards, but stay on when the light switch is all the way to the right.
    I have pulled the bulbs and tested OK. Checked the fuses and they are OK. No warning lights on the dash.
    Do these cars have a relay?
    Any controller for the DRL?
    Could it be the main light selector switch?
    Dec 2008
    Sydney/Canberra
    Do you have power and ground at the low beam bulbs?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Sep 2018
    I would say yes to ground as all the other lights in each headlight unit works, only the low beam are out.
    Don't have a wiring diagram to check.
    Pacific Paradise QLD
    Sep 2018
    Thanks for that. Still no wiring diagram but heaps of other good info.
    I think it may be the main switch. Anyone in Adelaide have one I could try?
