Our new Polo recommends higher tyre pressure than I've ever seen before on a tyre placard. Actually close to what I'd put in anyway.
front 270kPa = 39 psi
rear 250-280kPa = 36-39 psi
spare 280 kPa = 39 psi
same pressure for tyres 185/60 R15 or 215/40 R17
It's the first time I've seen an official recommendation for lower pressure in the rear with a light load. Have been doing that for many years. So what gives?
Interestingly, the Continental tire pressure guide shows much lower pressure for Polo 6R, which should be the same as 6C
front 190-210kPa = 28-30 psi
rear 190-230kPa = 28-33 psi
higher for the GTI with same tyre size as above:
front 250-290kPa = 36-42psi
rear 270-310kPa = 39-45psi
